Terry and guys I recently used MM to redo my 1985 tub. Prior to him 2014 doing job in 2003 just the rust sports were repaired by another company. Well in 2014 he redid whole tub and month later the ORIGINL rust spots reappeared and MM repaired and thirty days later again appeared.
Now the tech says for me to remove the tub drain which he replaced with a new one and call him and he will repair tub rust around the drain from underneath thru the drain hole ?
IS HE PULLING MY LEG or is their enough room for him to work with putty from under tub while tub is installed and all work thru drain hole
Mr. Terry I would really appreciate any input from you and your Terry's pirates (old comic book hero's) experience working with tubs
I have reread my problem and am confused so do not be offended after you read it and I blame my confusion on the water
Thanks
Sonny says hi from :
Home of The Rio Grande and land of Oil Patch
Thanks
