newbie here
Discussion in 'Toilet Forum discussions' started by recliner5@insightbb.com, Sep 9, 2007.
  1. recliner5@insightbb.com
    recliner5@insightbb.com New Member
    Sep 9, 2007
    greetings to all, my name is terp. The flush handle rubs against the porcelain, should there be some kind of washer made of tough plastic between the handle and porcelain? the flush handle does not operate very smoothly since it is rubbing the porcelain. I been thinking of putting some kind of strong plastic to use as a washer (like the thickness of a credit card), what do you think? thanks terp
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    did this handle come with the toilet or was it replaced with a new one.
    if it is a replacement then the wrong handle was installed for that brand. the cheap handles say universal but that's because they work on most toilets and mostly older ones.
  4. Terp
    Terp New Member
    Sep 10, 2007
    no this is a new toilet with new handle, the handle seems a little bowed, it is a powerflush. sometimes it keeps running after flush, read instructions on tweaking the the actuator w/screw. took handle off and it looked like it was bowed. do you think handle will break if I try to bend it? thanks terp
Similar Threads: newbie here
Toilet Forum discussions Newbie question Toto Drake CST743S, cleaning rim holes Nov 21, 2015
Toilet Forum discussions Hi Guys, Toilet Newbie. 14 Inch Width and 12 Inch Rough Jun 2, 2014
Toilet Forum discussions older brass copper cast metals appreciation--newbie Jan 30, 2014
Toilet Forum discussions A couple newbie install quesions Jun 17, 2013
Toilet Forum discussions Newbie question - Briggs toilet supply Jun 19, 2012
