Newb question...washer outlet box drains
Discussion in 'Plumbing Forum, Professional & DIY Advice, Tips & ' started by dabiz7, Jul 29, 2008.
  1. dabiz7
    dabiz7 New Member
    42
    Setup...currently have a washer outlet box with center supply and two drains, one on each side of the center supply. However, builder only hooked up left side drain down to p-trap and into drain/vent stack. The right side drain does not have a pipe hooked up to it.
    I am putting in a softener in this area and want to run the softener drain into this outlet box using the drain side that currently does not have a pipe running to it.
    Question...should I (1) connect a pipe to this drain and then tee into the left side drain above the current p-trap, or (2) connect pipe to right drain and plumb in its own p-trap into waste and vent stack?
    I am thinking (1) is right. Just wanted to get the experts opinion before I screwed something up!
  2. hj
    26,148
    drain
    You find it easier to make the connection using a "Y" in the drain riser and a 45 degree elbow to line up with the second opening.
Similar Threads: Newb questionwasher
Plumbing Forum, Professional & DIY Advice, Tips & Intro: 40 year old newb Jan 15, 2014
Plumbing Forum, Professional & DIY Advice, Tips & Newbe Here Oct 24, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Stupid newbie P-Trap question Sep 28, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Newbie Installing Water Filter -- Small Leaks Driving Me Crazy! Jul 9, 2013
Plumbing Forum, Professional & DIY Advice, Tips & Well Water Newbie Jun 22, 2013
