New Well Pump Now Small Leak Near Shut Off Valves
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by reddsky, Aug 21, 2011.
  1. reddsky
    reddsky New Member
    Aug 21, 2011
    Fort Worth, TX
    We just replaced our well pump due to old pump surging. Guys were able to drop the pump another 40' which is great; especially since we are amidst a severe drought. They also adjusted the water pressure to higher than it was. Everything is great e.g. we have ample water pressure and can now run sprinklers at night and still have water in the house!
    Fast forward to approximately 30 days later. Determined we had a small leak at one of the sprinkler heads so needed to shut off water to that part of the system. We have two shut off valves. One is for the house and the other for barn, sprinklers etc. When I got into the box, I noticed some minor moisture on top of the pipes and what appear to be 'nuts' of some sort? I went ahead and turned off the water so I can dig and repair the sprinkler. It seemed as though the 'leak' diminished or quit altogether (?) while that valve was closed. When I went back to re-open the valve, I could hear the water coming through and bingo...the area began to leak albeit minor. Has this somehow been caused by the new pump and increased water pressure?
    I will be calling the company that installed the new pump etc. tomorrow, but wanted to see what I could glean prior.
    btw, I am a girl and have basically NO plumbing knowledge whatsoever. :confused:
    Thank you for any insight.
  2. reddsky
    reddsky New Member
    Aug 21, 2011
    Fort Worth, TX
    Anybody????
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The higher pressure should not be a cause for a leak. It is just a leak and needs to be fixed.
Similar Threads: Pump Small
Pumps and Tanks Well Forum & Blog. Water is life. Pump for a small scale drip irrigation system? Aug 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Efficiency curves for smaller pump? Feb 2, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pressure dropping and climbing on pump? small crack to blame? Oct 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. reduce sand in lines with a smaller pump or extend time between pump cycles Jun 21, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Well pump cycling - small changes Jan 5, 2006
