New well, need advice?
Discussion in 'Water Softener Forum, Questions and Answers' started by OcCam, Jun 24, 2010.
  1. OcCam
    OcCam New Member
    Jun 24, 2010
    Northern BC
    I have a new well on a property and a new house hooked up to the well. The well is 95 ft deep and the driller estimated flow at 19 gpm with the well filling to 55ft. I have a Franklin Electric 8-stage 3/4hp pump on a variable drive, PSI is just under 50 at rest.
    So far the well has flowed approx 500 gallons to my sewage lagoon. I am going to be sending a sample off to be tested tommorow as it is slighty cloudy (Clearing up) and tastes of Iron. In just 1 night I have rust stains in one of the toilets.
    I am pretty sure I will need a softener but am concerned about dumping brine from recharging into my lagoon. How big of an issue is the saltwater to a sewage lagoon? Will it kill off the natural process??
    Softener selection is pretty limited in my area so I may end up with autotrol or kenmore softener.... we'll see.
    thx
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    I would not be banking on either of the autotrol or sears unit working for a long time..
    First look at the water test when it comes back.. iron and hardness and ph ,, that kind of thing. then how many people and number of baths and bedrooms for the house... as that will say what size unit is going to be needed.
    If a system is cleaning say every 5 days there should not be much of if any issue with the brine discharge, but if say 24lbs every day or 2 times a day then that will most likely be a challenge for the long run.
    There have been a few studies on brine in the septic.. mid west university's have done them.. look them up.
  4. OcCam
    OcCam New Member
    Jun 24, 2010
    Northern BC
    Water sample sent in this morning, It will be a week to get results back from Vancouver.
    As for some of the other stuff... 2 adults, 2 little ones, 2 cats, 2 dogs, 2 baths, 3 bedrooms. My pump is rated for 10 GPM, 1 inch line to house reduced to 3/4 pex at house.
    My lagoon is 75ft circle at the top and 30-35 ft deep, all clay. I will update when I get results from the test.
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    You could use all of that 10pgm from the pump if the baths are going and kitchen at the same time..
    I would figure on 5-6 people using the system that you put in place.. and look for a system that can do a normal flow of 9gpm..
  6. Gary Slusser
    Retired
    Depending on the static water level, a 10 gpm pump can deliver more than 10 gpm but, if the peak demand gpm of the fixtures in the house call for more gpm the pump is undersized.
    A softener has to treat the max peak demand of the house and 9 gpm is the max constant SFR (service flow rating) of a 1.0 cuft softener which is too small for more than 1.5 regular bathrooms with no big tubs etc..
  7. OcCam
    OcCam New Member
    Jun 24, 2010
    Northern BC
    OK here is the quick results of the water test, I have some conversions to do but that will have to wait for a few days....busy busy.
    Analyte Units Nominal Detection Result Limit Guideline Limit Guideline Comments
    Metals Extractable
    Aluminum Extractable mg/L 0.020 0.005 0.1 Below OG
    Antimony Extractable mg/L <0.0002 0.0002 0.006 Below MAC
    Arsenic Extractable mg/L 0.0014 0.0002 0.010 Below MAC
    Barium Extractable mg/L 0.007 0.001 1 Below MAC
    Boron Extractable mg/L 0.417 0.005 5 Below MAC
    Cadmium Extractable mg/L <0.00007 0.00007 0.005 Below MAC
    Chromium Extractable mg/L 0.0009 0.0005 0.05 Below MAC
    Copper Extractable mg/L <0.001 0.001 1.0 Below AO
    Iron Extractable mg/L 1.99 0.01 0.3 Above AO
    Lead Extractable mg/L 0.0008 0.0001 0.01 Below MAC
    Manganese Extractable mg/L 0.281 0.0002 0.05 Above AO
    Selenium Extractable mg/L <0.0006 0.0006 0.01 Below MAC
    Uranium Extractable mg/L 0.0007 0.0005 0.02 Below MAC
    Vanadium Extractable mg/L 0.0002 0.0001
    Zinc Extractable mg/L 0.004 0.001 5.0 Below AO
    Microbiological Analysis
    Total Coliforms Enzyme Substrate MPN/100 mL <1.0 1.0
    Test
    0 per 100 mL Below MAC
    Escherichia coli Enzyme Substrate MPN/100 mL <1.0 1.0
    Test
    Heterotrophic Count - MPN/mL
    Aerobic
    SimPlate <2 2
    Physical and Aggregate Properties
    Turbidity NTU 29 0.1
    Colour Apparent Colour units 110 5
    Routine Water
    pH @ 25 °C 6.96 6.5-8.5 Within AO
    Calcium Extractable mg/L 192 0.1
    Magnesium Extractable mg/L 136 0.1
    Phosphorus Extractable mg/L <0.1 0.01
    Potassium Extractable mg/L 7 0.1
    Silicon Extractable mg/L 5.2 0.05
    Sodium Extractable mg/L 245 0.1 200 Above AO
    T-Alkalinity as CaCO3 mg/L 942 5
    Chloride Dissolved mg/L 1.78 0.02 250 Below AO
    Fluoride Dissolved mg/L 0.14 0.01 1.5 Below MAC
    Nitrate - N Dissolved mg/L <0.01 0.01 10 Below MAC
    Nitrite - N Dissolved mg/L <0.01 0.01 1 Below MAC
    Sulfate (SO4) Dissolved mg/L 628 0.05 500 Above AO
    Hardness as CaCO3 mg/L 1040 1
    Total Dissolved Solids Extractable mg/L 1790 1
Similar Threads: need advice
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers Well water test results back need advice for new setup Feb 1, 2017
Water Softener Forum, Questions and Answers Water softener placement advice needed Dec 18, 2016
Water Softener Forum, Questions and Answers Advice needed, well water, plumbing and treatment Oct 14, 2016
Water Softener Forum, Questions and Answers Need water treatment advice Oct 11, 2016
