BadDad
so the general consensus is that a VFD is not a good system?
The constant pressure performance and ability to work with a smaller tank using a VFD are certainly good things. However, the CSV will deliver the same constant pressure and also works with a smaller tank. They are both good systems. Just that you can pay 100 bucks a month to maintain the electronic VFD system, or 30 bucks a month for a CSV mechanical constant pressure system? This is why the installer and pump manufacture thinks the VFD system is best, while most homeowners think the CSV system is best.so the general consensus is that a VFD is not a good system?
Well I wouldn't say a VFD is like a Lexus LS460. But if it is, then a CSV is also like a Lexus LS460, which can be had for a Nissan Sentra price.This guy is looking for a Lexus LS460 job at a Nissan Sentra price, and that is not gonna happen.
I think he is starting an irrigated small farm. See post #3.Another thing you need to consider is....how much water does your family use on a daily basis? The national average is 75-80 gallons per day.
I'm not trying to be a "dick" either, but I think you fail to realize what goes into running a business AND the value of a quality water system. Sure, you can't show it off like cherry cabinets, crown moulding, custom wainscoting, granite countertops, mahogany garage doors or crystal chandeliers, but without water, the rest of it is useless.
4 people X 80 gpd= 116,800 gallons a year x 15 year system life =1,752,000 gallons, divided into $12,000 = .00000856 cents per gallon. Tell me that isn't the best deal on earth.
why would you assume i dont know what goes into running a business?
I've been running the family business for over a decade. maybe that is exactly why i have a hard time justifying the price.
I'm kind of confused about the whole proposition. If you want to save money you can probably get by with a much smaller pump/system. You're over-complicating things. If your well makes enough water can the cistern or at least delay it for future uses. Go with one pump/tank system, use the smaller pump that requires smaller wire and smaller pipe. I'm betting you can make use of a much smaller pump and overestimating how much water you really need.
Then you should know that the $12,000 price tag is an absolute bargain, especially when you consider the equipment & experience required to this job. Did I mention the warranties?
I would venture to say that your local grocery chain has a greater markup percentage wise on on the items they sell.
well, if i have no choice then i have no choice. but first i will try to get a better deal...
