Alternety
Like an engineer
I am putting together the design for my new water system. I would just like all the expert eyes to tell me if I am doing something wrong.
Residence on well. The basic system is a 3 GPM well with deep pump, 1500 gal unpressurized storage tank, pressure pump, whole house filter for indoor water with seperate unfiltered branch for irrigation.
Filter will support a maximum flow rate of 11 GPM and a continuous rate of 4.5 GPM. Pressure drop is 5 PSI @ 4.5 GPM. House has 3 full and two half baths. Pump will provide 25 GPM. I have two WX-302 tanks (used manufacturers sizing chart) and one 80 GAL tank (currently used with well pump for temporary water).
My thinking is to put the two large tanks between the pump and filter. This would also feed the irrigation branch. Pressure control goes here. This optimizes pump cycling. I will also need a check valve in this configuration to prevent backflow through the filter. That check valve should be between the filter and the first two pressure tanks.
I was going to just tie the filter into the house supply but I am now thinking that I should use the third tank on the house side of the filter to level out pressure variations caused by the drop across the filter.
Any thoughts?
Any thoughts?
