New Water Heater Problem
Discussion in 'Water Heater Forum, Tanks' started by jti67, Feb 12, 2009.
  1. jti67
    jti67 New Member
    Feb 12, 2009
    I recently installed a new electric water heater in our house, a 50 gallon Whirlpool. The problem is the water is plenty hot but there doesnt seem to be the same pressure or flow rate of hot water at the shower head, the mixing valve has to be closer to the hot side then with the previous heater and we have to tweak the control during the shower to keep it comfortable.
    We are on a well and our old heater was 18 years old. I would appreciate any help.
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    your first mistake was whirlpool
    I hope that you did not install a whirlpool
    Energy smart electric heater, cause their are
    tons of ghosts you can chase in those dogs....
    If you have pressure balanced shower faucest
    it might have to do with that also...
  4. hj
    heater
    "Plenty hot" and "as hot as the old heater" may not be the same. If your thermostat is set lower than the previous one, then the way you operate the shower valve will be different also.
  5. jti67
    jti67 New Member
    Feb 12, 2009
    Yes, it was an energy smart talked to few people said they had no problems with thiers. I have tried diffrent water temp still have same problem.
    Thanks for the replies wish I would of found this site before installing new heater.
Similar Threads: Water Heater
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Yesterday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
