New water heater and new problem???
Discussion in 'Water Heater Forum, Tanks' started by Brockman1, Mar 25, 2009.
  1. Brockman1
    Brockman1 New Member
    Mar 25, 2009
    Hope someone can give me some advice on this issue. I had a new water heater installed and ever since when we use any water in the house anywhere the pipes rattle after the spout is turned off. Why is this happening since it did not do this before installation. How can I fix it without calling back the repairman? Thanks in advance....
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Just on the hot side¿
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    nail down the pipes
    pipes usually rattel becasue they are loose somewhere and
    are doing a water hammer sort of thing...
    the man probably did not notice that their was a gap
    in the lines after the new heater went in
    all you should have to do is get some pipe clamps or some wire and nails and simply secure the pipes down better around the water heater....
    odds are that is all it is....
  5. Brockman1
    Mar 25, 2009
    it actually sounds like the pipes in the walls are rattling and that wasn't the case before hand. Could I have air in the pipes? Both hot and cold rattle after water is turned off. Even the little bit of water used to fill the ice machine back after dumping causes the pipes to rattle. Any thoughts?
  6. jadnashua
    What's your water pressure? Are the supply valves to the house and WH fully open?
    It sounds like somewhere the pipes aren't clamped down well. The plumber may have removed or loosened one or more to get the new WH installed, then failed to replace or tighten them. Just like when you take your foot off the accellerator in your car it doesn't immediately stop, the water, once moving tries to keep going. It's sort of like hitting a brick wall when a valve is turned off quickly..the water tries to keep going, and can't through the now closed valve, so the pipe moves to disipate the energy. You need to either clamp the lines so they can't jump and bang into things, or install hammer arrestors. The whole thing gets worse if the pressure is high...it's like hitting a wall at 60mph verses 1mph.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Check for a loose washer on the valve you used to turn off the water to the water heater when it was changed...
  8. hj
    Loose washer in the valve to a water heater? That would imply a globe valve and they are not supposed to be used for a water heater, and any REPUTABLE installer would have replaced it if there were one there. It could be flow controls in the heater connections.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Well, we sometimes find the difference between a perfect world and the real world...
  10. Cass
    Cass Plumber
    Nov 12, 2005
    Did you have the old heater installed or was it there when you bought the home?
    I bet the dialetric was rusted 1/2 way or more closed reducing the flow and not allowing the pipes to vibrate...until it was replaced and there was good flow once again...
Similar Threads: water heater
Water Heater Forum, Tanks New Water Heater - Scale, High pH / Alkalinity Saturday at 6:41 AM
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Feb 15, 2017
Water Heater Forum, Tanks Help picking electric water heater Feb 11, 2017
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
