New Washing Machine
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Barneyn, Dec 20, 2007.
  1. Barneyn
    Barneyn New Member
    Nov 15, 2007
    I an installing a new front load washing washing and running the drain tube through the second floor instal location and out by normal means. The instructions tell me to instal a syphon break 29 inches from the drain tube.
    What is a syphon break and why do I want one.
  2. sjsmithjr
    sjsmithjr In the Trades
    Dec 12, 2005
    Geologist
    Knoxville, Tennessee
    If the washing machine drain hose can not be looped higher than the water level in the tub, you'll need to install a syphon break. If you don't install one, the tub will never fill as water will be syphoned out as fast as it goes in.
    -Sam
  4. Barneyn
    Barneyn New Member
    Nov 15, 2007
    Thanks Sam. So if I buy a longer drain hose, loop it above the machine and still use the floor drain, all should be good if I read you correct. Same principle as a dish washer.
Similar Threads: Washing Machine
Plumbing Forum, Professional & DIY Advice How To Drain Utility Sink To Washing Machine Drain? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Help - washing machine hose and standpipe issue Jan 20, 2017
Plumbing Forum, Professional & DIY Advice Washing machine wall box suds backing up. Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Washing machine inlet hose lifespan Dec 31, 2016
Plumbing Forum, Professional & DIY Advice Washing machine water feed shaking around Dec 31, 2016
