New tube - Drain and over flow question
Discussion in 'Shower & Bathtub Forum & Blog' started by jimmaher, Jan 27, 2009.
  1. jimmaher
    jimmaher New Member
    Jan 25, 2009
    I am replacing 40+ year old tube. My waste and vent is copper.
    The tub drain and over flow do not look great. If I replace at slipnut joint can I use plastic and connect it to copper nut?
    I am also installing a pedestal sink. Is there a basic rough in height?
    Thanks
    Jim
  2. hj
    drains
    IF you get the right kind of plastic waste and overflow unit it SHOULD attach to the copper drains. The height of the pedestal drain may depend on how the pedestal itself is constructed so you either have to have it ahead of time or get a drawing showing the drain location.
  4. jadnashua
    Bottom line on a pedestal sink install: there is NO standard in where the supply and waste pipes need to be for either height or offset from the centerline. Some are VERY restrictive, some are more forgiving. To be safe, you really need the thing or a good drawing with the manufacturer's specs in hand before rough-in, or to determine if you can fit with an existing setup.
Similar Threads: tube Drain
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog Diverter leaking from inside tube. please help identify/locate part Sep 12, 2015
Shower & Bathtub Forum & Blog What to do... Tube replacement or refinish, cast iron vs americast Aug 1, 2013
Shower & Bathtub Forum & Blog Need solution for short stop tube on Moen Shower Valve Sep 9, 2009
Shower & Bathtub Forum & Blog Tube overflow cover replacement Jun 30, 2009
