New tub shower combo supply question
Discussion in 'Shower & Bathtub Forum & Blog' started by WiWilliam, Apr 17, 2014.
  1. WiWilliam
    WiWilliam New Member
    Apr 8, 2014
    Wisconsin
    So I'm building a new bathroom and have decided I want 3 things in the shower/tub. A tub filler, a shower head, and 1 hand-held head. I found that Grohe makes a Retro-fit system which would be supplied by a normal single shower head off a pressure balance valve. It comes with an external diverter. I'm curious if this is a smart way to go or should I just run a separate in wall diverter? Also I've never had a thermostatic control valve and I know I like to take much hotter showers then my wife, does this present a problem?
    Thanks for your help.
    [​IMG]
  2. jadnashua
    My personal experience with Grohe is they make solid stuff...I have a few of their fixtures in my home. I first experienced one of their thermostatically controlled valves in a hotel in London, England. While the pressure was bouncing all over the place, the temperature was stable. Most of them have two controls...once for volume and one for temperature. In this manner, you can set your preferred temperature and then just turn the water on and off. Not sure on the one you pictured. If a local store doesn't carry the repair parts, you can still order them pretty quickly, which is important, too. While they are required to have a stop at (normally about 105-degrees), the temp control knob can be moved beyond that stop usually by pressing a button. I find it nice as you can set your preferred temp, and never worry about it even as the WH starts to run out. While it doesn't magically make hot water, it will keep the temp constant as long as there's enough hot water to meet your set point.
  4. hj
    To me, that "conversion" looks like something we used to find at hardware stores to add a shower to a tub, and is NOT something I would recommend if this is going to be a "full rebuild" of a tub/shower unit. as for temperature, a Delta "two handle" valve would give you the option of selecting the temperature, by positioning the handle first, then turning it on for the volume you want.
  5. jadnashua
    Delta also makes a thermostatically controlled valve option. But, on their volume/temp (not thermostatically controlled), it is controlling the fixed mix of hot and cold, not the actual temperature which will change with the seasons as the incoming cold changes, or as the WH starts to cool off near the end....there, a thermostatically controlled valve will maintain the same temp until there's not enough hot water to do it. Whether that additional complexity and valve cost is useful to you, only you can decide.
    FWIW, my tub/shower valve is entirely external because the 'wet wall' was compromised by both a pocket door and a main air duct behind it. Turning the tub 180-degrees would have made for major rework of the entire drain system. So, external has its uses, and if you like the style, go for it.
  6. WiWilliam
    Apr 8, 2014
    Wisconsin
    HJ your right the more I look at that the more it looks like something that was an afterthought.
    That sounds interesting!
    Thanks for the advice I'll figure something out.
Similar Threads: shower combo
Shower & Bathtub Forum & Blog Is volume control really necessary for bathtub/ shower combo? Mar 4, 2017
Shower & Bathtub Forum & Blog shower to tub combo Nov 28, 2015
Shower & Bathtub Forum & Blog The right diverter valve for a tricky tub/shower combo Feb 23, 2015
Shower & Bathtub Forum & Blog Old Moen Moenique shower/faucet combo nobody recognizes. Feb 21, 2015
Shower & Bathtub Forum & Blog Wish to do it right the first time - Tub and shower combo remodel Feb 8, 2014
