New Trane 2stage VS CAC...Ques about wiring
Discussion in 'HVAC Heating & Cooling' started by vzw, Sep 8, 2012.
  1. vzw
    vzw New Member
    Sep 8, 2012
    New York
    Just want some advice as if 2 stage is wired correctly. The condenser model # is 4ttr5061e and the airhandler is 4tee3f66a1000aa...If i look at the install manual for the AH is says to use the Ylo terminal for the low stage, and the Y terminal for the 2nd stage, and the blue to blue ,BUT, In the condenser install manual...it states the Y from the AH should go to the Yel/BLK on the condenser, the BLK from the AH to the Yel/RD at the condenser, and the blue to the blue. Which is correct??? I currently have it hooked up the 1st way, but how do I know the condenser is running in the correct stage? Please help. Thanks.
  2. vzw
    vzw New Member
    Sep 8, 2012
    New York
    EDIT>>>>>>>FIgured it out. It was wired up wrong! I rewired it the 2nd way, and both stages and speeds now work! Im amazed at how many hack techs are out in the field.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Tranes need to be installed by Trane factory authoriized techs....who have access to factory tech support for just such questions
  5. vzw
    vzw New Member
    Sep 8, 2012
    New York
    They were "factory trained" techs. I wont let them in my house again! Hacks...How easy is it to get "factory trained"?
Similar Threads: Trane 2stage
HVAC Heating & Cooling Question on capacitor size on Trane AC unit Aug 6, 2015
HVAC Heating & Cooling Are the Motor Bearings Bad? Trane XL80 Feb 17, 2015
HVAC Heating & Cooling A/C Crankcase Heaters (on a Trane) Aug 16, 2012
HVAC Heating & Cooling Trane A/C System Capacity Reduction Dec 7, 2011
HVAC Heating & Cooling Trane XL80 - gas valve info needed Jan 17, 2011
