New toilet too big for bathroom
Discussion in 'Toilet Forum discussions' started by sheryl169, Jun 15, 2013.
  1. sheryl169
    sheryl169 New Member
    Jun 15, 2013
    st. louis
    I have an extremely small bathroom and had a toilet installed three days ago. I had consulted with the plumber and trusted him to select the correct size toilet. My previous toilet was an old American Standard lowboy which allowed just enough space for sitting comfortably. The new toilet is an American Standard cadet comfort height. The new toilet is perhaps 2 to 3 inches deeper (from back of tank to end of bowl) than the other toilet. Now my legs are just squished up against the bathtub. I paid $400 for the toilet and installation. I also need to mention that the previous toilet was installed incorrectly and there was quite a bit of labor involved. I can't afford another toilet installation and I would like to purchase a Toto toilet or some similar toilet that would fit the space. I also wanted a push button toilet and was told that that kind of toilet tends to malfunction and/or leak quickly. Help! Do I have the option of requesting a new toilet? I guess I am just stuck with this one until I can afford a new one.
  2. Terry
    Aug 17, 2004
    If size was going to be an issue, then that should have been discussed before the purchase.
    That water has already passed over the dam. And if you gave him an okay to do the work, it's done.
    All ADA toilets will be 1.5" longer.
    And then not all are the same. Checking the spec sheets will let you know beforehand which ones are more compact.
    A round bowl will be from 26.5" to 28" in depth
    An elongated bowl (ADA) can be 28" to 30"
    All of these will have some offset from the wall on a standard 12" rough.
    If you need compact and tall, then the choices narrow
    TOTO does make a CST423EF bowl, Promenade, that is tall and round.\
    And the Entrada, round bowl, with universal height. CST243EF
    [​IMG]
    http://terrylove.biz/toilets/98-toto-cst243ef-entrada-toilet.html
    Some of the dual flush bowls have a button on top. I've haven't had any problems with those.
  4. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    The Toto Aquia with dual flush and buttons on top is reliable. Some of the warehouse-club brands with pushbuttons don't leak, but there are documented issues with their pushbutton units malfunctioning with some frequency.
    As to the size issue, it wouldn't hurt to talk nicely to the plumber. Maybe he wants you to be happy and will work with you on a compromise.
  5. hj
    toilet
    When you asked for a "comfort height' that almost required it to be an "elongated bowl" which IS 2" longer than a round front bowl.
  6. wjcandee
    wjcandee Wise One
    Apr 27, 2012
    New York, NY
    Round and ADA Height, as Terry Says. 26.125" long plus about 3/4" between toilet and wall.
    CST423EF without Sanagloss or CST423EFG with Sanagloss (about $30-60 more)
    Spec Sheet: http://terrylove.com/pdf/cst423ef_spec.pdf
  7. Terry
    Aug 17, 2004
    Some people perch at the end of an elongated bowl, rather than sitting back.
    The sitting position between round and elongated should be the same. The "extra" room is just that. Extra room in front of you. Guys get that.
    I do hear from women sometimes that expect to always set at the very end of the bowl. It's not meant for that.
    You sit on the back, where it's rounded for a round lower portion of the body. :)
  8. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    HJ was right when he stated that comfort height almost meant elongated bowl. The keyword is almost. The Toto Promenades are a rare exception. Also, Terry is spot on with his comments about where the sitting should be.
Similar Threads: toilet bathroom
Toilet Forum discussions Upstairs master bathroom toilet Wednesday at 11:51 PM
Toilet Forum discussions flushing one toilet or using bathroom sink draws water from other toilet tank? Feb 6, 2016
Toilet Forum discussions Bathroom Door Hits Toilet, need a solution Mar 23, 2014
Toilet Forum discussions help, limited space in bathroom, need short toilet Nov 15, 2013
Toilet Forum discussions Need a toilet to fit over baseboard heat in a very small bathroom May 12, 2013
