New Toilet install Toilet flange too low and question on pipe diameter
Discussion in 'Toilet Forum discussions' started by ducktoller, Dec 7, 2013.
  1. ducktoller
    ducktoller New Member
    Dec 7, 2013
    Mukilteo
    Our house was custom built in 2000 and in our powder room we have hardwood floors and we just had them refinished. I removed the old Kohler
    Wellworth toilet which was prone to clogging alot and decided to replace it with a Toto Drake 2. I have already replaced all the the other toilets in the house a few years ago with Toto Drakes and they have been great. Well when I pulled the old toilet I noticed the top of the closet flange is about .25 inches below the finished hardwood. I also notice the old wax ring was either doubled up or one of the extra deep ones with a horn on it. With that horn on it doesn't it also impede the flow due to the reduction of diameter?
    I was thinking I should try a flange extender but how thick should it be? Should I bring it up so the top surface is flush with the finished floor or even higher? I have read a few negative things about them need . Are there some better then others? I see some people cement them to the ABS flange with ABS cement and others just silicone them and bolt them together.
    Lastly I could actually cut a hole in the garage ceiling and replace the closet flange completely and lengthen the riser but I don't have a pipe cutter that big so I would be buying another tool and fill in the wood underneath raised flange etc then patch the sheet rock but in the garage not a big deal.
    Any expert opinions here ?
  2. Terry
    Aug 17, 2004
    Use two wax rings and be done with it.
    Unless you cut out the flange and replace it, you could be buying yourself trouble by trying to "raise" the flange with "extenders".
    Extenders need to be sealed completley, or your wood floors will take the hit if there is any leakage.
    Consider this; there was no leaking with the previous installation. What you had before was an older toilet bowl made before the latest improvements.
  4. ducktoller
    Dec 7, 2013
    Mukilteo
    Thanks Terry so one other quick question. Should I use one with the horn or just two plain wax rings stacked?
  5. jadnashua
    Normally, those with the horn are to be avoided, but when stacking two, it has some advantages. WHen used singly, the plastic can provide a leak path if there's not enough room (height), or, in some flanges, the horn can be compressed, and actually close up (get pinched). But, when you have extra height, it helps keep the extra wax from the second ring from collapsing into the flange and blocking things. So, stack the one with the horn on top of the single wax ring on the bottom...set the toilet down, smush it into place, then snug up the nuts then add some sealant around the front 3/4 of the toilet. Dry fit the toilet first to ensure it doesn't rock, and if it does, place shims so when you place it down for good, it is solid. The wax won't rebound if it rocks, and you could end up with a gap in the wax if it rocks.
  6. Terry
    Aug 17, 2004
Similar Threads: Toilet install
Toilet Forum discussions Can hear other units flushing after installing new toilet Mar 20, 2017
Toilet Forum discussions How do I Install Toilet Flange to Stubbed Pipe in Concrete Slab Nov 20, 2016
Toilet Forum discussions Plumbing Hacks Video, installing a toilet with Terry Love Jun 28, 2016
Toilet Forum discussions Toilet Flange install question for 3" pipe May 28, 2016
Toilet Forum discussions DXV Fitzgerald D2205CA.101 toilet installation with pictures Apr 2, 2016
