new toilet install on concrete. Must be screwed down or not?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by M_south, May 29, 2012.
  1. M_south
    M_south New Member
    May 29, 2012
    Duvall, WA
    Several days ago our contractor re-installed the drain for a toilet. The first install was in the wrong place so the toilet drain had to be moved 6 inches further from the wall. The contractor cut the cement and added new. It seemed to setup fine. This week we've gotten to the DIY part of the project where we install the toilet. We purchased a standard round flange and pipe connector. the flange has 4 screw holes. We purchased cement screws and attempted to screw the flange in to the floor. The screws don't hold. They immediately unseat. The holes are just outside the pipe and the pipe is wrapped in foam. The area where the screws are installed is not stable enough to screw into with out crumbling.
    The floor contractor says that the toilets installed on cement floors don't get screwed into the floor. that the pipe (of the pipe and flange apparatus) is too long and needs to be trimmed. No screws need to be used.
    Fact or Fiction?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Unless it's cast iron pipe with a cast iron flange it needs to be screwed down.
    john
  4. Terry
    Aug 17, 2004
    You may need to go to a hardware store and pick up one of the repair rings to hold the "closet bolts".
    They allow for drilling farther out.
    [​IMG]
  5. hj
    I have NEVER screwed a flange to a concrete floor, regardless of the pipe's material, as long as the bedding material under the concrete is packed tightly around the pipe.
  6. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    The main reason PVC flanges fail it because there not fastened to the floor. If there screwed down it gives more support to the flange preventing it from breaking were the closet bolts come through it.
    John
  7. M_south
    M_south New Member
    May 29, 2012
    Duvall, WA
    Thanks guys,
    Terry do you know where to buy one like this? the flanges sold by my local true value and home depot don't have those extra wide screw holes like the one you picture.
  8. Terry
    Aug 17, 2004
    The flat repair ring pictured is normally at Lowes or Home Depot.
    It's what we carry on the vans.
    I don't buy them there, they cost twice as much at the hardware stores than where I pick up my supplies. That's the beauty of being in construction.
    [​IMG]
Similar Threads: toilet install
Plumbing Forum, Professional & DIY Advice Toilet Flange Install Question Dec 29, 2016
Plumbing Forum, Professional & DIY Advice Flange problem with replacement toilet install Aug 4, 2016
Plumbing Forum, Professional & DIY Advice How do I install a toilet to this?... Lead bend no flange Mar 20, 2016
Plumbing Forum, Professional & DIY Advice Macerating Toilet Installation Location Dec 9, 2015
Plumbing Forum, Professional & DIY Advice Very slow flush on new Toto Aquia toilet. Bag of installation hardware in outlet (update) Nov 16, 2015
