New Toilet/Bathroom Drain Trouble
Discussion in 'Toilet Forum discussions' started by the.timmer, Oct 26, 2011.
  1. the.timmer
    the.timmer New Member
    Oct 26, 2011
    Michigan
    Over the weekend we installed a new bathroom to have one on the 2nd floor. Ran out of time before being able to install everything, but were able to get the tub connected to the drain and set the toilet. Left the sink drain sticking up about 6" above the subfloor for now. When it came time to test the toilet, it doesn't drain. When you flush it, the bowl fills, but nothing goes down.
    I pulled the toilet, ran a line through the bowl out the bottom of the toilet, it went through - no problem. Took the toilet outside, filled the tank and flushed it - no problem. I then set the toilet again and it flushed somewhat, but was inconsistent. Ended up finding that the wax ring was no longer making a seal and air & some water was being pushed out the side/bottom of the toilet but most of it went down the drain. Went and got a new wax ring which sealed it, but also put me back at my original problem. The toilet will flush but won't drain.
    I'll post a picture of it later, but the drain first connects into the rest of the drain system from the basement at a 4" pvc, goes up through the first floor to the second and then reduces to 3". It then goes to a Y connection and splits off to the toilet, and the other side goes to the sink, then to the tub.
    The tub drains fine, and when pouring water from a bucket through the toilet flange, it seems to drain fine. Toilet is a Kohler Wellworth Classic, which is what we have in the first floor bathroom. We were thinking it may be a vent problem, but the sink drain that is 2' upstream from the toilet is wide open, and I've tried drilling a 1 1/2" hole in the drain, a few feet downstream from the toilet but it still has the same result.
  2. BizzyBeePlumbing
    BizzyBeePlumbing New Member
    Aug 21, 2011
    Raleigh,Nc
    do you have any vents on this new bathroom you installed? was it inspected? did a plumber complete the work? when you flush the toilet, does the water come all the way to the rim? swirl? is the closet bend holding water or the drain? did the toilet come from home depot? if the drain is done properly, then the toilet is defective. There isnt a test plug anywhere in the line is there? the line could be partially stopped up, taking water from a bucket but not from a toilet flushing.
  4. the.timmer
    Oct 26, 2011
    Michigan
    Think I've got it figured out. We weren't thinking about it when we roughed in the plumbing a year ago and put a trap on the toilet drain. Now if only we didn't already lay the subfloor, thinset and durock... /cry
    This should be an episode on Renovation Realities. ;)
  5. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    That could do it!
    Where did you get the idea of putting a trap in a toilet drain?
  6. the.timmer
    Oct 26, 2011
    Michigan
    My brother wasn't thinking. He's a builder who dabbles in everything. Fortunately he's not the type to make mistakes twice, but unfortunately my house was the one he made it on. Oh well, live and learn.
  7. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Sounds like your brother is a accident looking for a place to happen.
    John
  8. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Sorry, but I can't resist. I should be ashamed to make fun of your dilemna, but we all get in to them sooner or later.
    http://www.google.com/products/cata...a=X&ei=S2epTtTxMof40gHBufWpDg&ved=0CFoQ8wIwAA#
  9. the.timmer
    Oct 26, 2011
    Michigan
    He does good work, but only does plumbing work occasionally. Everyone makes dumb mistakes, even in their own field.
  10. BobL43
    Mar 25, 2011
    Long Island, NY
    Yes of course, me included. At least you didn't tile it yet.
Similar Threads: Toilet/Bathroom Drain
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions Another slow draining/bubbling thread Nov 13, 2016
Toilet Forum discussions Drain mystery: What is it? Oct 15, 2016
Toilet Forum discussions TOTO TU451.10-A Drain Valve and THU440-A Sep 30, 2016
Toilet Forum discussions Help! Broken flange that was resting on crumbling mortar, bolt down drain!! Sep 15, 2016
