New third zone always radiates heat
Discussion in 'HVAC Heating & Cooling' started by mainemom, Jun 12, 2009.
  1. mainemom
    mainemom New Member
    Jun 12, 2009
    Maine
    I have a FHW system and recently added a 3rd zone on the second floor for a MB suite. The first floor has always had 2 zones. Each zone has it's own circulator pump and thermostat.
    Some of the pipes on the second floor remain warm/hot even if I set the thermostat to the OFF position. I even disconnected the thermostat thinking it was faulty, but it didn't help. During the winter I kept the thermostat at 60and had to sleep with open windows (I'm in Maine). Now that the weather is warmer, I have the thermostat in the OFF position and there is still heat radiating from the pipes - enough to make the room very uncomfortable. The oil burner tech who installed the system doesn't think there is a problem.
    I will appreciate any info which will give me a heads-up concerning the problem before I call in another technician.
  2. jadnashua
    Get another tech!
    I think you need to install some check valves to prevent flow unless the specified circulator is on.
  4. patsfan78
    patsfan78 Web Development | HVAC
    Jun 3, 2009
    Maine
    New technition
    There is clearly a problem, call a new service company.
    I am just going to point out that oil companies like to sell oil. Ask around and find someone more reliable.
    The is most likely something simple, such as incorrect wiring.
    Mike
    www.hitechheat.com
    Home Heating Solutions
Similar Threads: third zone
HVAC Heating & Cooling Third floor a/c Mar 18, 2008
HVAC Heating & Cooling Adding a Zone to a Boiler Jan 9, 2017
HVAC Heating & Cooling Mini Splits, Single vs Multi Zone Condensers Sanity Check Jul 21, 2016
HVAC Heating & Cooling Floor radiant zones normally open or normally closed Jan 5, 2016
HVAC Heating & Cooling Taco zone valve coming loose Dec 16, 2015
