whatthewell
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I had my pump replaced last year by a professional plumber. The well is about 60-70' deep. About 4 months later, the pump wasn't pumping. Had the plumber out again, and he smacked the switch with a wrench a few times and the pump came on. He told me that the tank was going bad, and that was somehow causing the switch to stick off. He explained it better than that and it sounded like it made sense at the time....I really don't remember all the details, but the bottom line was that I knew the tank was going bad and figured that someday in the near future I'd wake up to no water and have to replace the tank which is something I am comfortable doing myself.
Well, that day was today. I replaced the pressurized tank, the switch, check valve, gauge, and all plumbing to the house feed. Basically everything from the stick of pipe leading to the pump to and including the tank.
When I turn on the pump, it pumps water, but it won't go in the tank. I took the tank back out thinking there must be a plug or something in the bottom but not so. The switch is 40/60, and there is 38lbs pressure in the tank. When the pump is on I can run water in the house (with very low pressure) because it's actually just pumping water right from the well to the main feed and bypassing the tank.
What is wrong?? Why won't the water go in the tank????
Thanks for any input....I really need a shower!
