New sump pump question-cycles frequently
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by famattjr, May 3, 2010.
  1. famattjr
    famattjr New Member
    Feb 11, 2009
    New Jersey
    I just had new pumps installed in my sump. I have a high water table, I have french drains feeding a lot of water, especially during storms, into my sump. My sump liner is a standard plastic one sold in Home Depot, 20" in diameter, 25"deep. My old pump, while high in hp, could not keep up during big storms. I now have as my primary a Zoeller M137 1/2hp and as a backup a 1/3 hp Zoeller M53, both connected to a Sump Pro in case of power failure. My concern is due to depth and water table, the main pump is going on every 90 seconds, pumping for just 5 to 6 seconds. Seems the main Zoeller is not adjustable, by my measurements it goes on at 9 1/2 inches of water height. My old one used to go on at about 18" of water, so if there was no storm, it would be off. The 1/3 hp backup is installed 5" higher than the primary. Should the main pump have been installed higher so it would cycle less frequently, and when it went on, would pump longer? Problem there, though, is if installed higher it would not pump as low. The installer told me, don't worry, once it lowers the water table it will cycle less frequently, but it's been about a week. It concerns me that it is cycling so frequently.
    In reply to a thread on this forum titled "Sump pump/pit conundrum"
    drick commented: "What kills pumps is frequent cycling or severe flow restriction. Ideally you want your off time between cycles to be as long as possible. 5 minutes is great. 1.5 minutes is tolerable as long as it doesn't run this way all the time. Anything below that isn't good for the pump"
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    I think that the problem is that you have an automatic pump thats going to go on by the depth it's set on. If you changed the height of the pump it would come on at a higher water level but it still would not pump the pit empty or change the cycling.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    To increase the pumping time an adjustable switch can be installed which will permit a wider range of water level between cycles.
Similar Threads: sump pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
