Actually stray voltage is still a big problem for dairies. They have gotten better at filtering the electric noise from VFD's but it is still a problem. Other things like florescent lighting also add to the stray voltage problem. There is not much problem with the little VFD on the vacuum pump for the milking machine. But for larger VFD's like on the water pumps, each additional VFD in the area adds to and has an accumulative effect on stray voltage. Cows are very sensitive to electricity. They can tell if an electric fence is on just by putting there nose close to it. So a 4 volts shock from stray voltage when drinking water will keep them from drinking the amount they need. And since milk is just water that has been processed through a cow, if they don't drink enough water, they don't produce much milk.
All these electric filters also have heat loss, which decreases the efficiency. There have since been many more instances where replacing VFD's with CSV's has increased milk production as well as electrical efficiency. A lot of people still wrongly claim a VFD conserves energy. When pumps with centrifugal impellers need to buck a static head, as is the case with any pump system, decreasing the speed of the motor can greatly increase the power used per gallon produced. There is no more efficient way to pump water than to run a pump at it's best efficiency point using standard AC voltage with no electricity wasting filters or energy using VFD's.
A recent letter from a person with a small VFD pump system at their house just gave me some good statistics. He said over many years of use the pump had only consumed a total of about 1,000 watts of power when pumping water. But the tally shows the VFD's uses 40 watts when in standby mode. So over the same time the VFD had used over 4,000 watts while just sitting idle, just as any computer will do when in standby mode.
