New Sink. Need a double check on DWV fittings
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chrishallowell, Jul 14, 2010.
  1. chrishallowell
    chrishallowell New Member
    Jul 14, 2010
    Hi experts,
    I'm installing a new sink in an addition and I could just use a double check on my DWV fittings.
    Ok, I can't attach my drawing so I'll have to summarize....
    DRAIN:
    Sanitary tee to connect the P-Trap(Horiz), the vent(Vert up), and the drain(Vert down).
    90 degree sweep elbows for vertical to horizontal drain turns.
    90 degree sweep elbows for horizontal to horizontal drain turns.
    45 degree elbow for horizontal to horizontal drain turns.
    45 degree wye to tie in the new horizontal drain with an existing horizontal drain
    VENT:
    How do I tie in the new vent(runs horizontal) to the existing vent(runs horizontal) in the attic? Do I just use a short tee?
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    If you are tying into a vent only you can use just about anything; if you use drain type fittings make sure that they are run with the flow toward the vent.
  4. chrishallowell
    Jul 14, 2010
    ok, great. Thanks for responding.
Similar Threads: Sink Need
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
Plumbing Forum, Professional & DIY Advice Need some guidance with sink drain Nov 9, 2016
Plumbing Forum, Professional & DIY Advice Need help on planning washer & utility sink setup Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Need help installing utility sink. Sep 7, 2016
Plumbing Forum, Professional & DIY Advice I am in need of options for my kitchen sink drain Sep 1, 2016
