new shower stems still leaking
Discussion in 'Shower & Bathtub Forum & Blog' started by bugguts, Aug 16, 2008.
  1. bugguts
    bugguts New Member
    Dec 13, 2007
    NYC Paramedic
    cen New Jersey
    after running to 3 stores to locate the right stem{ I beleive I have the right one )
    And finding a single shower steam socket w/o having to buy a set of 6,,,,,
    I replaed the stems,, turned the h2o on and no water cmae pouring out..until I opened the valves and water came pouring out..
    Now . Do I need to dope the caseing ,,,,,, or force it even more then I did
    It seems to me it coming out from around the valve , not the seat /washer.because when I turn the fauce off the h20 stops
    the valve also has another threaded fitting att he "front" that the stem comes out of ,,,, do I tighten that down as well...
    by the way it came with a small brass fitting , I assume is a replacement valve seat , I have no idea how I would get that into the shower manifold w/o ripping the wall down
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Well, we need some help....how about some pictures.
    You say you "think" you got the right part. That is a risky assumption in plumbing. We would like to see pictures of the old and new one. If this is a typical 2 or 3 handle shower, then yes the seat inside needs to be replaced. Yes, you need to buy another $8 tool to do that, or you could pay a plumber $100 for a service call. He will have the tools!
    There is probably a gland nut which tightens up the packing around the stem. The stem should be well lubricated, then tightening that by the proper amount will allow smooth operation with no leaks.
  4. hj
    leak
    So far we don't really know whether you replaced the correct unit, where the leak is, or anything else. It is like saying, "I replaced the doofus, but the thingamabob is leaking. Should I tighten it more?", when we don't even know if you tightened it enough.
Similar Threads: shower stems
Shower & Bathtub Forum & Blog Upgrading shower stems from compression to quarter-turns May 9, 2015
Shower & Bathtub Forum & Blog Measurements of the Schluter Systems Kerdi-Shower-ST Series 32"x60" 48"x48" & 72"x72" Jan 30, 2014
Shower & Bathtub Forum & Blog Insul-Deck Concrete Forming Systems - Tying them in with a barrier free shower Nov 14, 2013
Shower & Bathtub Forum & Blog Frozen Shower Stems Jul 8, 2012
Shower & Bathtub Forum & Blog Stems replaced, shower still drips. Old American Standard stems. Feb 2, 2012
