New Shower knob wont turn
Discussion in 'Shower & Bathtub Forum & Blog' started by njbill, Jan 29, 2009.
  1. njbill
    njbill New Member
    Jan 29, 2009
    About a month ago I installed a new moen 3 knob bath faucet set. Yesterday, the center knob that controls the shower diveter is VERY hard to turn. I took the knob off and put it back on and it had no effect.
    I have an older home and no real access to the internal stuff, as I just redid the enclosure..
    Thanks for your help
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Tear it out! It needs replacement.
    Dirt in the diverter stem which is common on a Moen. Doesn't take much for it to happen. I've been out on these 3 handle faucets and the answer is always sediment jamming the assembly.
    Good luck with that faucet!
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I wonder why people install those when pressure balanced valves are available...
    They must be cheaper down at big box...
  5. njbill
    njbill New Member
    Jan 29, 2009
    ANything else
    So there are no suggestions other than to tear it out. ANything???
  6. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    Take the knob off. Pull out the diverter and grease any moving part with clear silicone grease. See if the parts move freely in your hands. Replace everything back the way it was.
    Let me know how it turns out
  7. Dunbar Plumbing
    Apr 18, 2005
    Monthly?
    You know what happens if this works, and lets it go for 2 years? It'll take a chippin' hammer and a sense of humor to get that cartridge out.
  8. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    No,........ one time
    How many have you tried to repair.? The ones I have done have had no problems .I may get recalled after 1 year in an area with hard water, but the cartridges are free, diverters are free, hoses are free and so on. So who cares how often you have to replace it or repair it, if the parts are free.
    I repaired/greased my moen diverter in my home 4 years ago, and its still going strong
  9. njbill
    njbill New Member
    Jan 29, 2009
    moen reply
    Dear Valued Moen Customer,
    Thank you for your interest and support of Moen products. The issue you have described is usually caused by the diverter stem becoming seized within the valve. We have ordered a replacement diverter kit to correct the problem. Unfortunately installation instructions are not provided; however I have attached a parts diagram for your review.
    First you will need to pry the cap off of the diverter knob and then use a Philips head screw driver to remove the set screw. Then you will need to unscrew the packing nut and pull the stem out of the valve. You may need to clean inside the valve if you find debris, which may cause the stem to become difficult to rotate. Then install the new diverter and screw the packing nut back on to the valve. Then you can reinstall the handle.
    Should you have any questions, you may contact us by email (moenwebmail@moen.com) or phone at 1-800-BUY-MOEN (1-800-289-6636) or visit our website at www.moen.com. Our business hours are 8:00 a.m. - 8:00 p.m. Monday through Friday and 8:00 a.m. - 6:30 p.m. Saturday EST. In our continued effort to assist you in the future, we ask that you please retain your original receipt for all warranty claims.
    Nick
    Moen Consumer Services
Similar Threads: Shower knob
Shower & Bathtub Forum & Blog Valley shower knob brand or part number. Dec 5, 2016
Shower & Bathtub Forum & Blog Replacing the temperature knob on a shower panel? Jun 28, 2016
Shower & Bathtub Forum & Blog Delta shower diverter knob leak - can water leak into wall cavity? Nov 13, 2014
Shower & Bathtub Forum & Blog shower diverter knob not working May 29, 2013
Shower & Bathtub Forum & Blog Delta Shower Valve with Temperature Knob Jan 19, 2013
