Dave Stone
I am replacing the last few feet of 3/4" copper pipe that brings water from the street to my house and also replacing the ancient gate valve with a Sharkbite ball valve (SharkBite 22185-0000LF Ball Valve SB 3/4"LL) that I bought at Home Depot. This has Sharkbite connectors on both sides.
The water has not yet been turned back on at the street (and btw, the valve at the street apparently leaks, albeit very slowly because the end of the pipe had been dripping before I installed the vertical section--is this normal?) and the Sharkbite valve is connected at the current end of the vertical portion of the new section of copper pipe. I have not connected copper to the downstream end of the valve yet.
The Sharkbite valve was left CLOSED (lever at a right angle to valve/pipe) while I was away for about 30 hours, and when I just now checked it, the top of the valve was full of water and it had been spilling onto the ground beneath. So it appears that this is city water that has managed to get THROUGH the brand-new Sharkbite valve. I opened the valve and nothing happened--the pipe is full of water to the top of the valve.
Prior to pushing the valve onto the copper pipe, I didn't mess with it at all except to remove the plastic inserts and then open and close the valve a few times to admire the ball action inside. Do these valves need any tightening or adjustment? The lever action is not loose; it offers some resistance.
Or did I just get a bad one?
Thanks.
Thanks.
