Paul brzezinski
I recently drove a new shallow well. I have 5 sections 5' each and a 36" point so it is roughly 28' deep. I fill the well and it goes back down fairly quickly so I don't believe the point is plugged. When I prime the pump and let it run until it shuts off from the pressure switch it will run a lot of water until the pump kicks back on and can't keep up. It turns into surging water pressure to the point it stops for a second between surges. The pump is new. So I'm not sure if the well can't provide enough water or something else is wrong. Not sure what to try next.
