New Service Panel Question
Discussion in 'Electrical Forum discussion & Blog' started by jparrie, May 18, 2008.
  1. jparrie
    jparrie Automotive Locksmith
    Jan 21, 2008
    California
    I'm installing a new 200A Service panel while remodeling. This unit has 42 slots, but there is no way that there are enough knockouts for even half that many cicuits. Does the NEC alow doubling or even tippling up on the nm romex through each knockout opening? Secure them all to framing within 8" of the service? Any derating required?
    TIA
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    This message was too short so I made this white.
  4. jparrie
    Jan 21, 2008
    California
    Thanks! Can you point me to a source for this connector rating information?
  5. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
  6. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Pretty much every NM connector that looks like that will accept at least two cables of varying sizes.
    You have to look at the label or instructions.
  7. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    Two wires in every hole (12 & 14 gauge). In our county we can use the yellow or grey plastic fittings. Very easy to use.
  8. jparrie
    Jan 21, 2008
    California
    I'm not familar with those, who makes them?
  9. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    I'm not sure who makes them, just go to home depot and look for the plastic inserts by the metal connectors. They're fast and quick and hold the wire great.
  10. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Are you talking about these
    [​IMG]
    or these
    [​IMG]
  11. Marv
    Marv New Member
    May 7, 2008
    Accountant
    Northern Illinois
    I've used the second one. I've also used the yellow ones that are similar (and the yellow with double inputs).
  12. kd
    kd New Member
    Dec 11, 2006
    If your inspector allows you to use grommets they must be stapled within 8 inches of the box. Some allow lots of cables going thru one big grommet. Others say one cable--one hole.
  13. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Its a code violation to just use a grommet... even if you do staple within 8" of the box...
  14. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Also, "others" CANNOT simply say that. They must be able to back it up with a written code citation, which in this case they probably could not do.
    MOST NM connectors ARE rated for more than one cable.
Similar Threads: Service Panel
Electrical Forum discussion & Blog 200 amp service split between two panels Mar 14, 2016
Electrical Forum discussion & Blog Service Upgrade & Sub Panel Installation Apr 17, 2015
Electrical Forum discussion & Blog What is the new year bringing, especially in residential, especially in service panel Jan 5, 2014
Electrical Forum discussion & Blog Basic electric service panel questions Jul 17, 2013
Electrical Forum discussion & Blog Service Panel Change Out.. Need Help Determining and Sizing Panel May 28, 2013
