New pump or replace check valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lwerdmann, Apr 22, 2013.
  1. lwerdmann
    lwerdmann New Member
    Dec 15, 2007
    Hi everyone, first off I'll give you some of my initial problem then my quick fix and now need advice on my next step.
    My pump would cycle then as soon as it shut of the water would start flowing back into the well. I caught this after a guy at the electric company was giving me suggestions for really high electric bills. I decided to add a check valve in the house as a temporary solution, only temporary because of everything I've read on here about above ground check valves.
    That procedure seems to have solved the problem although now I have a couple of other problems. One, a get a very nice solid hammer noise when the pump kicks off. I also get a very slight amount of air on occasion. OK after going through the forums, I know I have to get my pump problem fixed and get rid of the check valve.
    My question is should I replace the pump, six years old, unknown manufacturer, but I think it's 1/2 hp (could be wrong though, well is 180' or should I just have them replace the check valve on the pump, if they can? Just not sure if I'm going to the expense of pulling the pump if it would be worthwhile to replace instead of fix.
    Thanks in advance for any suggestions.
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    If the pump is pumping the water out quickly and turning off and on at its normal levels then it is fine. All pumps in the Chicago area have check valves on them above the pit. They make silent check valves were the thud you hear when the valve closes is not so pronounced. Also you will need to drill a 1/8" hole in the discharge pipe just near the top of the pump. The key is to take the pump out of the pit and drill in such an angle so the water spraying out sprays down into the pit. This helps prevent the check valve from locking up.http://www.aymcdonald.com/en-US/Sump-pump-check-valves.html
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    I think SewerRatz is talking about a sump pump. If this is a well pump, you will need to pull the pump and replace the check valve on the pump. No drilling holes anywhere as with a sump pump.
    As to replacing the pump while you are at it, it depends on the cost of the labor. Those pumps don’t cost much, and the average life is 7 years. Doesn’t mean you can’t get 15-20 years, but that depends on how bad you let it cycle. The fact that your check valve is out, is a clue that you have been letting it cycle a lot. I would lean towards replacing the pump while it is out.
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    He must have missed the 180 foot deep bit.
    I agree with valveman that you are close to the average lifespan and that it may already have been shortened. Also, it is disconcerting to hear that air is getting in the line. That suggests other problems and the leak-back might not be at the pump.
  6. SewerRatz
    Nov 20, 2008
    Chicago, IL
    Sorry bad habit of mine which cost me a 100% grade back when I was in school. I should read more carefully. My advice is for a sump pump. I just happen to have sump pumps on my mind since all the flooding we had here in Northern Illinois. So please disregard my earlier post, it is advice for sump pumps.
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    No Problem SR. We appreciate your help!
Similar Threads: pump replace
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Selecting a replacement pump Nov 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump will not cut out after pressure switch replaced Jul 16, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Submersible well and pump replacement questions.... May 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Reliable replacement sewer pump grinder for eOne 2000 series? Mar 29, 2016
