New Pump Needed?
Discussion in 'Irrigation / Sprinkler Forum' started by bizgoz, Apr 26, 2008.
  1. bizgoz
    bizgoz New Member
    Apr 26, 2008
    My sprinkler pump is about 25 years old. About 10 years ago I had it rebuilt. It worked fine until a few weeks ago. Some work was being done behind my house and I had to disconnect the pump for about a month and then extend the intake pipe (from a canal) about 25 feet in length. The run from canal to pump is about 10 feet vertical and about 120 feet long. Since I redid it (and replaced the check valve) it primes okay, but has very low pressure. Any thoughts on rebuilding this ancient pump vs. replacing it? Thanks!
  2. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Extending the intake line increases the friction losses, and reduces pump performance. If it must be longer, then you may need to replace it all with a larger-diameter pipe.
  4. bizgoz
    bizgoz New Member
    Apr 26, 2008
    Got it. And as far as replacing the pump goes, is there a preferred internet vendor for pumps?
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
Similar Threads: Pump Needed
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Shallow well pump issues Sep 24, 2016
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
Irrigation / Sprinkler Forum Timer for irrigation pump? May 13, 2016
