Johnboy300
First- this is a great forum. It has already been very helpful.
Ok- long story as short as I can. I bought an 130 yr old farmhouse with a 3/4 horse jet pump, a waterlogged OLD steel pressure tank and galvanized leaky plumbing. I decided to redo everthing but the pump which seemed to be fine. (I did a volume test at the laundry sink and got 7.5 gpm.) I replaced all the plumbing with pex and installed a whole house filter, softner and a wel-x-trol WX-202 20 gallon tank. The pressure switch was set at 25 -45 in the previous system which I have not touched at all. I dropped the pressure in the the new tank to 23 psi to make it 2 pounds below cut in. The system pressurizes to 45 psi and then shuts off properly. If I open a fixture the pressure draws down to 25 and then the pump kicks in. My problem is this: If I leave the fixture open the pump never catches up. It just hovers around 30 psi until I close the fixture. Then it gains quickly. I know this can't be right and the old setup could always catch up (however waterlogged) What did I do wrong? How do I fix this? I really dont want burn up my pump.
THANK YOU!
THANK YOU!
