Locke426
Just moved in to an old house. The washer/dryer hookup is outside the house, right up against the wall of the kitchen where the kitchen sink is (it's a double sink, in case that ends up being relevant). I don't have hardly any plumbing experience but I've never seen a set up like this and I don't really understand why it would be this way. See the first picture. There are two pipes. The taller pipe on the left is where the washing machine drains to. The shorter pipe on the right is where the kitchen sinks drain to. When you run the sink, the water just overflows out the top of the pipe on the right and spills all over the deck behind and under the washing machine. I'd leave it the way it is but the water, mixed with food remnants and such ends up smelling awful. So, feeling capable, I decided I would just run pipe from the sink drain pipe to the washing machine drain pipe. See second picture. Now, the sinks won't drain. I'm guessing it's a gravity problem because the pipe goes slightly higher than the height of the sinks. Any ideas on the cause or how I can make it all good? Thanks in advance.
