New Moen Tub spout not flush with tile wall
Discussion in 'Shower & Bathtub Forum & Blog' started by dmtrunner, Dec 6, 2009.
  1. dmtrunner
    dmtrunner Health care analyst.
    Dec 6, 2009
    Saint George Utah
    The plumber installed the tub spout with a slight gap between the tile and the spout. Water will get behind the spout. Should I caulk this to close the gap? Or get the plumber to remove the gap by changing the pipe or another solution?
    [​IMG]
  2. jadnashua
    SOme spouts have a gasket. IF yours does, it shouldn't be a problem. IF not, then it's not a bad idea to caulk it. Does the spout screw on or is it a push-on type? If it screws on, you might be able to get another turn on it. IF it's a push on, if there's any movement in th pipe, without pushing against the back while pushing it on, you may never get it tight. Normally, the pipe behind would be anchored. Does the spout pull out if you pull on it or is it solidly anchored?
  4. Terry
    Aug 17, 2004
    I would use some clear polyseamseal on that.
    I'm surprised you didn't go with Toto on your porcelain fixtures.
    Toto is the best.
  5. dmtrunner
    Dec 6, 2009
    Saint George Utah
    The plumber was surprised there was no gasket that came with it. I believe he told me this one screws on and we can't get one more twist as it is already tight on the other side. We were thinking the pipe fitting is not true 90 degrees and is causing the problem.
  6. dmtrunner
    Dec 6, 2009
    Saint George Utah
    I found your form after I made the purchase, which is really to bad. Your forum is excellent a treasure trove of information. Thank you so much for doing this. I think I will use these for a while and then get something else. Is there a discussion thread on one piece unit vrs two piece toliet tank and bowl?
  7. Terry
    Aug 17, 2004
Similar Threads: Moen spout
Shower & Bathtub Forum & Blog Hole too big in tile for tub spout. The fix...Moen 3857. May 13, 2016
Shower & Bathtub Forum & Blog Remove Moen 3809 diverter spout Sep 6, 2013
Shower & Bathtub Forum & Blog moen spout Jan 26, 2009
Shower & Bathtub Forum & Blog Leaking Moen Bathtub Spout Diverter Aug 31, 2007
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
