New Moen Cartridge - Very Little hotwater
Discussion in 'Shower & Bathtub Forum & Blog' started by Redman67, Nov 28, 2006.
  1. Redman67
    Redman67 New Member
    Nov 28, 2006
    Hi... I just replaced a badly leaking Moen Cartridge with a new similar one.
    Model 1200.. I couldn't tell what the original was so I got the closest look alike. It fit in ok accept for the clip.. I had to really work at it to get the retaining clip in..(had to bend the clip in all kinds of directions to push it in)
    I turned on the water and all seemed ok.. no more leak. But now the water does not get hot... it doesn't even get very warm. To make matters worse I can't find the original cartridge. Anyhow, anyone have any ideas? I was thinking maybe its not the right cartridge. Shall I try another type of cartridge? Maybe the 1225..
    [​IMG]
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Most times the cartradge needs to be turned 180 degrees. You should get some hot / warm water when you put it in the position for cold. This would show it needs to be turned 180. Try pulling it out and cleaning the valve better and slicking it up with a little plumbers greese then re install it 180 from where it was.
  4. jimbo
    jimbo Plumber
    The 1200 is the brass cartridge and the 1225 is plastic, but usually they can be used interchangeably.
    You should not have to monkey with the clip, and that concerns me, because if it snaps, you will have a surprise! Something is probably not put in just right, and get a new clip.
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    I agree with the others. Look carefully at the exploded diagram in the instructions that came with the cartridge. Make sure the cartridge is positioned correctly and push it in place. The clip should go in fairly easy and you should get hot and cold water.
  6. Redman67
    Redman67 New Member
    Nov 28, 2006
    Thanks
    Thanks for the info..... the clip thing now kinda worries me.... I surely don't want any problems. maybe i'll take a pic and post it so you can see..... are pics allowed here? This cartridge thing was supposed to be an easy do-it-yourselfer.... at least thats what someone told me.. Maybe something is preventing the cartridge from being pushed in all the way.. because for the clip to go down easy the cartridge has to go in a little bit more, but It doesn't... so I have to kinda bend the clip somewhat.
  7. Redman67
    Redman67 New Member
    Nov 28, 2006
    here is a pic
    Ok.. I'm gonna try to send a pic.. Can you look at the retaining clip... what did I do wrong... I had to bend it so that it would go all the way down... Its late now.. I'll try your suggestions tomorrow...
  8. Cass
    Cass Plumber
    Nov 12, 2005
    O.K. no wonder the clip was so hard to get in.
    You have the cartradge in and it is 90 degrees off.
    The 2 ears of the cartradge must be at 12:00 and 6:00 not 9:00 and 3:00 and the "new" clip that your going to get will slide past them on either side.
    I must say I have never seen anyone install a cartradge like that. I laughed so hard I almost fell off my chair. No wonder you had such a hard time with it.
    Doing it right will be much easier I think.
Similar Threads: Moen Cartridge
Shower & Bathtub Forum & Blog Moen s3600 valve cartridge removal Dec 10, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp replacement cartridge M1222B Oct 31, 2014
Shower & Bathtub Forum & Blog Moen Cartridge back piece of housing broke. Help Please! Mar 30, 2014
Shower & Bathtub Forum & Blog moen posi temp cartridge issues Dec 8, 2013
