Hello experts,
I recently identified that all of the toilets in my house are in need of flush valve seal replacements. It is clear that these seals are eroded and brittle. I have replaced the valve seals with new ones. However, the new valve seals seem to be stiff and do not make a tight seal with the plastic "cup" that comes down over them.
I noticed that the older valve seals were no longer flat and instead have conformed to the shape created between the plastic cup and the bottom of the tank (kind of like the rim around the edge of a plate). The new valve seals are completely flat and are stiff (being new). I believe that they need to be softened up a bit to create a better seal, but this is only a guess from a novice plumber (namely, me).
I would be extremely appreciative if anyone has an tweaks to make the new seals form a nice, tight seal.
...and thank you to all of the experts who even take the time to read this, let alone offer a suggestion.
Thank you,
Punkyb
Thank you,
Punkyb
