ibmargie
My one week old leach field has water on ground by number 4 line (we had four installed). I watched this system be put in and all lines were level, the distribution box is level pulled top to check and water level in tank.
Going to do best I can describe what I think problem is. When the white pipe for number 4 came out of the distribution box and at some point connected to the black lines (4) for the septic field. The leak is at that joint where the pipe from the distribution box and leach field pipe meet. The connection was made at the top instead of at the side like 1,2 and 3. My thinking it came off when back filling. I can barely scape the ground with shovel to remove dirt and water seeps up. The further I go up the drain field to number three the further down I have to dig to see water. There are just the two of us here. I have not done laundry in a week nor have I showered but my husband does every night. No garbage disposal or dishwasher.
No perc test done on this field just a visual from inspector to see type of soil (sand,clay, rock). Perc test done seven years ago on old drain field which some lines collapsed and had water above ground on two lines at end of field. Do have valve to turn to switch between drain field or just take a little pressure off the new field if need be.
I have taken distribution top off and taken the #4 line in the box and turned it so no water goes in that line unless water level becomes very high - in short lines 1,2 and three are carrying the water now. Should I have done this and it has only been a couple days with hot weather and not seeing any difference.
I appreciate any help. My husband's health prevents him from helping in this matter.
Thank you
ibmargie
Thank you
ibmargie
