New Lavatory P-Trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by pensfan84, Nov 12, 2009.
  1. pensfan84
    pensfan84 New Member
    Oct 27, 2009
    Pittsburgh, PA
    I'm installing a new lavatory in a fully gutted bathroom - I am able to take care of the drain and vent properly (thanks to many of you on this forum) but my question relates to the fittings for the P-trap. Everything is 1 1/2" ABS, so I am wondering which fitting I should use to connect the sink drain to the drain/vent in the wall?
    I'll need to know how to connect the p-trap to the fitting too
    I would like to use a plastic p-trap.
    I'm pretty much lost as to what to do here - potentially the easiest part of this remodel...maybe I'm over-stressed :p
    Thanks in advance
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You should adapt the drain to 1-1/4. That is the standard size for a lavatory basin. These fittings are readily available at any plumbing supply store, it's call of all things, a trap adapter! You can easily recognize it, it has threads on one end and there is normally a white cap screwed to that. P traps are also easily found in the plumbing supply house. The usually come in a package, like a kit, that has all of the components you will need. Sales people usually can answer questions about traps without getting into too much trouble. After the adapter is solvent glued to the drain, everything else is hand tightened slip joints. The only place you can go wrong is with the cone shaped and thin flat washers.
    [​IMG]
  4. hj
    slip nuts
    I ALWAYS tighten those "hand tight" connections with a pair of Channellock pliers.
Similar Threads: Lavatory P-Trap
Plumbing Forum, Professional & DIY Advice Please help me identify the brand of this lavatory faucet Oct 18, 2016
Plumbing Forum, Professional & DIY Advice Moen Monticello, Mystery Lavatory Faucet? Jun 10, 2016
Plumbing Forum, Professional & DIY Advice Using 2" with Lavatory Oct 17, 2015
Plumbing Forum, Professional & DIY Advice Lavatory drain gasket not seating Sep 27, 2015
Plumbing Forum, Professional & DIY Advice Loose Grohe lavatory faucet handles? Aug 3, 2015
