New Lavatory Faucet: No water
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by spolivier, Jun 16, 2008.
  1. spolivier
    spolivier New Member
    Jun 16, 2008
    I installed a new lavatory, drain and faucet today. All went fine, ran the faucet on cold, checking for leaks. Then ran the hot (and yes, the hot shut off valve was open). There was a chug (normal, I thought), and then nothing. And after that, no water at all.
    Kohler faucet. What gives?
  2. Solan
    Solan New Member
    Jun 15, 2008
    Been there before
    Spolivier,
    I have been in a similar situation. I used a piece of bread to temp. stop the extra water in the pipes before soldering and it got a bit lodged in the pipes. I opened up the bath tub faucets (to remove the air) and after some chugging out shot the half dissolved bread and the water started flowing.
    Good luck,
    Solan
    [​IMG]
  4. Garydaplummer
    Garydaplummer Union plumber/pipefitter-self employed
    Jan 5, 2008
    Mechanicsburg, PA
    Exact same issue
    I had this happen with a Kohler faucet. It was a Kohler Bancroft lav faucet with factory-installed supply lines. As always after turning the water on and before connecting the faucet to the angle stops I flushed the water lines. Cold worked fine, trickle of hot water. I removed the cartridge, opened up the water supply, the water did not flow. I reconnected everything and the water ran fine for a second or two then a bumping noise and we were back to a trickle, hot only. I even tried switching the hot and cold cartridges to see if it was a cartridge problem. It was not. I ended up calling Kohler and they sent a replacement faucet complete under warranty. The support rep thought it may be a manufacturing problem inside the faucet body.
  5. spolivier
    Jun 16, 2008
    Thank you for the replies. I think it is a Kohler Bancroft too, although I will have to check - this was at a friend's house. I'll post the outcome later. Just checked, it is a Kohler Fairfax.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Check the aerator to see if it is blocked with debris.
    Did you use Watts Floodsafe Faucet Supplies??? They are prone to false trips among other problems.
    [​IMG]
  7. Sandpiper Plumbing
    Sandpiper Plumbing Plumber
    May 4, 2008
    Northern by birth, Southern by choice
    Check the aerator...most likely cause of blockage.
  8. spolivier
    Jun 16, 2008
    It was the aerator.
    Thanks for all the posts. The aerator was blocked, and I am eating humble pie!
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Not uncommon when you disturb the supply system... No need to eat humble pie! Glad you fixed the problem and thanks for posting back!
    Can you imagine what we feel like going to a customers house finding a clogged aerator and charging for the visit?:eek:
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Do you perhaps wonder why the answer came so quickly? May it's because it is a very common problem that many have encountered but didn't figure out until trying every other remedy possible. No need to feel embarrassed, you at least have a happy ending to the the problem.:D
Similar Threads: Lavatory Faucet
Plumbing Forum, Professional & DIY Advice Please help me identify the brand of this lavatory faucet Oct 18, 2016
Plumbing Forum, Professional & DIY Advice Moen Monticello, Mystery Lavatory Faucet? Jun 10, 2016
Plumbing Forum, Professional & DIY Advice Loose Grohe lavatory faucet handles? Aug 3, 2015
Plumbing Forum, Professional & DIY Advice Lavatory faucet stem identification Dec 5, 2014
Plumbing Forum, Professional & DIY Advice Which size of angle supply 1/2" or 3/8" for lavatory faucet installation? Feb 5, 2013
