New Kohler Cast Iron Tub and Gerber Bath Tub Drain Reuseable?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cloves, Apr 22, 2014.
  1. cloves
    cloves Member
    Feb 9, 2010
    New Jersey
    Hi fella's, we are currently replacing our old cast iron bath tub with a new Kohler Villager. I have a Gerber brass bath tub drain (20 gauge) that is only a few years old I would like to reuse since the new traps are so expensive. So I was wondering if this was at all possible? As you can see in the photo I am going to have to get a new "T" to connect the drains which isn't a problem.
  2. hj
    quote; As you can see in the photo I am going to have to get a new "T" to connect the drains which isn't a problem.
    Actually, that may be your BIGGEST problem, because it has to be one made specifically for that drain assembly.
  4. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    "since the new traps are so expensive"
    When you change your oil in your car, do you keep the old filter, since it only has 3000 miles on it and it looks new?
    Drain assembly is about $30. Compare to the tub, it's peanuts.
    Use common sense and a new drain assembly.
  5. cloves
    cloves Member
    Feb 9, 2010
    New Jersey
    hj, parts are readily available online from a supply house.
    dj2, a car filter is made of paper which gets clogged as oil and particle pass through it. This is a brass waste and over flow which costs about $150 bucks. The tub costs 330 bucks, so not really sure how you are making this comparison.
    The only cheaper options are to go with pvc.
  6. Terry
    Aug 17, 2004
    If I'm installing in an area without access, the inspector wants a solvent weld waste and overflow.
    That would be PVC or ABS
    I rarely install brass W&O's anymore. When I price them the other day, I was surprised at the costs. And the lack of quality that I was used to.
    If you have an intact drain that is three years old, that's still pretty new.
    If you have access for later replacement even better. They will leak after a while. That's why they are no longer code.
  7. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    If you get a new tee be sure it is a Gerber so the bucket seals properly. Otherwise, the tub won't hold water.
  8. hj
    quote; hj, parts are readily available online from a supply house.
    "Parts" are available, but are they the RIGHT parts? If not the assembly will go together okay, but the drain will not hold water. The trip "bucket" MUST be close slip fit, so it can move but also keep the water sealed off.
Similar Threads: Kohler Cast
Plumbing Forum, Professional & DIY Advice Kohler cast iron tub Sep 14, 2016
Plumbing Forum, Professional & DIY Advice Kohler cast iron tub install question Dec 31, 2015
Plumbing Forum, Professional & DIY Advice Chipped Kohler shower pan: Acrylic over cast iron Mar 12, 2013
Plumbing Forum, Professional & DIY Advice Kohler Forte Tall Single Lav Repair, K-10217 Saturday at 12:07 PM
Plumbing Forum, Professional & DIY Advice 1970s(?) Kohler/Bradley/Cole Shower Control Leaks Dec 13, 2016
