New kitchen sink, questions about drain lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dutzig, Sep 12, 2009.
  1. dutzig
    dutzig New Member
    Sep 12, 2009
    FL
    Novice speaking - Purchased and started install of new sink, disposal, faucet. The new sink is deeper than the original. After getting some things in place, there are two issues (maybe more) that I do not know how best to resolve - with the main question being is this DIY work?
    1. Drain line going into the wall is at the same level as the disposal discharge tube (see image 1). The drain line going into the wall is about 15" from the cabinet floor to center, and the cabinet floor is about 5" above the finished kitchen floor.
    2. The left strainer basket is directly over the slip joint, so I can't just simply put the p-trap back in (see image 2).
    Thanks very much in advance.
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Having gone as far as you have, I would guess you can "git 'er done!"
    Your disposer might have a little water always standing in it, but I do not know whether that is actually a problem.
    A couple of 45s or even short-turn 90s (possibly streets, or one of each) might let you put the trap back in place on the drain line, then jog back over and up to the strainer basket. To do that, you can purchase a tailpiece and adapter to go into the first fitting under the strainer, then a short piece of pipe can go down into the trap. And if you cannot get all of that in there, you will likely end up opening the wall and lowering the fitting coming out.
  4. jimbo
    jimbo Plumber
    The extension you will need to piece together on the disposal side will be more easily accomplished with glue up pipe than slip joint tubular, but no matter now you do it, you will have a deep trap and it will drain slowly.
    Although is seems like a lot of work, you will be better off in the end if you open the wall and lower the san tee .
  5. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    The proper way is to lower the TY in the wall. The easy way is to reverse the bowl of the trap so the shorter end is on the disposal. This will work with most traps. There are some traps that do not have enough slip on the lower end of the bowl to do this. But if you look around I'm sure you can find one.
    John
  6. hj
    drain
    A double Y rather than the single one you have would have made the left hand connection easier, and you will probably still have to find one and use it. There are NO traps that make a good connection when reversed. They have to be installed in such a way that there is tension on them so the tailpiece cannot come out of it.
  7. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    In my area they have traps with a slip on the lower half of the bowl that is as deep as the tees on any end or center outlet waste.
    John
Similar Threads: kitchen sink
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Kitchen sink still leaks Feb 15, 2017
Plumbing Forum, Professional & DIY Advice New kitchen, new sink, drain too high! Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink smell from non-disposer side Feb 12, 2017
