New Kitchen Sink Installation
Discussion in 'Remodel Forum & Blog' started by rmcjec1, Sep 15, 2008.
  1. rmcjec1
    rmcjec1 New Member
    Sep 15, 2008
    I have a new self-rimming kitchen sink to install. Manufacturer recommends placing sink in place and using sealant around the edge. I have read several suggestions on using plumber's putty or caulk at edge before placing on countertop and then applying caulk after in-place. Is this better? Is a latex silicone blend okay for this or would pure silicone be much better?
  2. jimbo
    jimbo Plumber
    The idea is to never see any caulk at all, if possible. Put the bead UNDER the rim of the sink, thus making the seal. What oozes out should be very neatly wiped away, leaving only the tiniest bead of caulk visible. Any bead applied AFTER the sink drops in is by definition going to be too big. Caulk is a maintenance headache....subject to staining and mildew. The less, the better.
    100% silicone is best, but not user friendly ( not water cleanup )
    A siliconized kitchen/bath latex like DAP is good enough.
  4. rmcjec1
    rmcjec1 New Member
    Sep 15, 2008
    Thanks Jimbo. I'll give that a try.
  5. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    If you use silicon, you can cut that with rubbing alcohol. 90%.
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I use denatured alcohol.
Similar Threads: Kitchen Sink
Remodel Forum & Blog Kitchen sink Nov 15, 2011
Remodel Forum & Blog Composit Granite kitchen versus Stainless Steel kitchen sink? Aug 2, 2010
Remodel Forum & Blog Single-Basin Kitchen Sink better than Double? Apr 30, 2010
Remodel Forum & Blog need help with installation of undermount kitchen sink Jan 16, 2009
Remodel Forum & Blog Kitchen Counter Sink Hole Standards Dec 7, 2008
