New kitchen...older drain...I need to vent!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rberken, Oct 5, 2005.
  1. rberken
    rberken New Member
    Oct 5, 2005
    New cabinets installed, new flooring, took opportunity to look at old drainage. Bottom line, there appears to be a very slow leak at galvanized/pvc threads right below floor (or above basement ceiling...take your pick) and against outside wall. Musty odor and moist/semi moist "dirt" are my indicators.
    Bottom line? I'd like to cut out the old stuff at castiron, leaving copper? vent/vent(s), then redo drain to main stack.
    2 Sinks drain via loopy,twisty,ferncled pvc and wye together before entering wall and connecting to castiron. Dishwasher has its own "open top", pvc drainage pipe that also enters wall and connects to cast...appears to have its own vent (both are below a window, so I assume they travel horizontally toward a nearby laundry room to vent.....)
    Is it possible to simply cut old stuff out at copper vent pipe(s), then bring the vents into area under sink to a new drain? Then I could redo the labrynth of tubes that currently exist and hopefully consolidate some things (dishwasher, disposer) while still venting gases???
    NEW INFO: was not a leak at threads, but rather, lack of ANY adhesive on PVC....I'm guessing prior owner primed PVC and forgot to glue! Still interested in any "takes" RE: venting options. Could I vent with a "y", angle up to vent?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    vent
    take this question to the general plumbing category and someone will set you straight.
Similar Threads: kitchenolder drainI
Plumbing Forum, Professional & DIY Advice Bathtub drain not connected to drain pipe; bathwater draining into foundation Feb 4, 2017
Plumbing Forum, Professional & DIY Advice Kitchen sink not draining correctly Jan 12, 2017
Plumbing Forum, Professional & DIY Advice Draining into Sump Pit Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Please verify my proposed re-venting/draining for washer Dec 9, 2016
Plumbing Forum, Professional & DIY Advice Dishwasher draining problem! Nov 5, 2016
