New homeowner outdoor water faucet problem.
twig
ohio
How do I keep the water from coming out of the stem of my outdoor water faucet when I turn it on.
DonL
Houston, TX
If it is one of those safe valves, You may not be able to keep it from dripping a little. What kind is it ?
It is best to turn it off when not in use.
Good Luck. Welcome to Terry's Forum.
Does your faucet look like this one? If so, is there a chance that the water is coming out of the vacuum breaker? That is very common. I just put a repair kit in one today.
If it is from the packing, you unscrew the packing nut and replace the packing.
twig
ohio
Yes it looks just like this .see the small yellow stem right after the green handle there is a hole were the water shoots out when I turn it on.the hole has always been there and it worked fine in the fall.
Quarterball
Can you supply a picture? If the manufacturer's logo/markings are visible it may be possible to direct you to the proper location for repair or replacement parts.
