New home sprinkler system
Discussion in 'Irrigation / Sprinkler Forum' started by shakedown, Feb 14, 2007.
  1. shakedown
    shakedown New Member
    Feb 14, 2007
    I will be moving into my first home soon, and it has a lawn sprinkler system installed. I had the home inspected, and in the report it was noted that the sprinkler system poured water from the vaccum breaker. I have a picture of this and wondered what the problem could be. I have been doing some research online and cant figure out if its a AVP or PVB or what. If I attach a pic could someone determine the type and possibily the solution to what would cause water to come out of there and not any of the sprinkler heads? I'm pretty handy and would like to repair this on my own. Any suggestions?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It looks like a vacuum breaker to me. It's no doubt just stuck or sludged up. You can take the lit off and check it out.
    bob...
  4. hj
    thing
    It is a vacuum breaker, but it is an atmospheric one which cannot have the irrigation valves installed after it. It is leaking because it is worn out, however, not because it is the wrong one. Replace it with a pressure vacuum breaker.
  5. ed the head
    ed the head I have been in irrigation over 25 years
    Mar 8, 2007
    Irrigation
    Texas
    sprinkler system
    Hj is right on the money
  6. hj
    vb
    Oh, and dump the PVC piping above the ground, or at least paint it or it will become brittle and snap off the first time someone trips over it.
Similar Threads: home sprinkler
Irrigation / Sprinkler Forum Replacing a Goulds J10S 1 hp pump for home sprinkler system Jul 6, 2010
Irrigation / Sprinkler Forum Home irrigation pump start relay intermittent shut off issues Jul 25, 2013
Irrigation / Sprinkler Forum Connecting irrigation to water main with pex homerun system Apr 11, 2012
Irrigation / Sprinkler Forum new home owner Oct 23, 2009
Irrigation / Sprinkler Forum New owner of home - where are the system lines?? Jun 22, 2008
