New Handles & Spout
stressed
I'm a complete newbie to home repair/remodeling, but I'm learning and any help would be appreciated. :D
The tub handles and spouts were replaced in both my baths in the last 6 years or so. The problem is that the parts used were cheap and now look unattractive. Can I replace just the handles and spouts w/something nicer, or will the whole faucet need to be replaced? If I can replace just the exterior parts, are most compatible w/each other so it won't be hard to find replacements? Can I buy just the pieces, or will I need to buy a whole set and just use the pieces I need? Lots of questions because I'm lost. :confused:
TIA!
If you pull the handles off and bring them to a hardware store you may be able to find somthing nicer.
However, if the home is older there may not be very many choices left to you.
Most replacement handles there are the clear acrylic.
Another option would be to replace the valve with a new one. If you have access to the back of the wall, you will have an easier time.
If you have to access from the front, there are "remodel plates" that will cover up the hole needed to work on the replacement.
Moen makes one for their single handles faucets.
You can even get remodel plates for the two handle faucets.
e-plumber
DIY Senior Member
New York
Faucet Upgrade
If only the tub handles and spout were replaced, "fit-all" types were probably used, especially if it doesn't look good in such a short period of time. If you can identify the faucet brand, many times it is more efficient to purchase a complete faucet (exact brand & model) use only the trim and scrap the brass valve body.
stressed
Yep, The cheap acrylics are on there now
But I think everything on the inside was already changed. Just with a cheap set that came w/the acrylics. I guess I'll remove one and take it with me to see if I can find something nicer to fit. If not, I'll try buying a whole set-up and scrapping what I don't use. Thanks for the help!
Bob's HandyGuy
Senior Member
Matching handles is a job I would not wish on a friend. They do make universal chrome/acrylic replacements. If you try to mix models, the hard part is matching the grooves on the end of the stem. Also, the distance from where the handle ends to the eschutcheon is tough to match. It seems every manufacturer has a unique design. As someone suggested, I would buy a new, good quality faucet that is to your liking. Good Luck!
