New Gas range problem.. pipe size
Plumber69
Prince Rupert, British Columbia
Guy wants range hooked up. He has a line which ran to a fireplace which he took out. This line is 10 feet from where the range will go. Problem is its 1/2" od copper and will be about 45 feet total length from 1 inch black pipe to the range. Btu of range is 60,000. Meter is 100 feet to range. And it's a finished house. Putting a 2 pound meter will be last resort
Where do you find 5/8" plumbing copper tubing? IF you are using the gas table correctly, you do NOT change the size of the feed line unless you are making an additional fixture connection.
Too small for a gas range. IF you need 3/4" to start the run, you need it ALL the way to the stove. DO NOT use copper for a gas line if it is going to be on the exterior of the building where it could be damaged.
Plumber69
There's lots of houses in my town where copper was used on exterior wall. I'm pretty sure code permits this
Dj2
California
In my city, we use only black iron pipes, connectors, yellow tape and pipe dope for gas. In certain cases (or inspectors), you might get by with galvanized.
Price wise, black iron is less expensive than copper or galvanized.
