New Garage Door Installation
Discussion in 'Remodel Forum & Blog' started by Mike50, Jun 14, 2008.
  1. Mike50
    Mike50 DIY Senior Member
    Jan 8, 2006
    Southern California
    I'm replacing my old door. A local company uses the doors manufactured by Windsor Republic Doors. Any comments/considerations to be aware of before installation are appreciated. Quote is $800.00 (with windows) $600.00 without.
    Mike50
  2. jadnashua
    I went with a nationally available brand, for better or worse - bought it at HD. INjected foam filled metal panels, high R-factor, lifetime warranty. Materials cost was around $500 for the size I needed, installation was easy; not sure what their installed price was. If you don't have an HD credit card, you can get 10% off your first purchase and take a year to pay for it without interest (but make sure you DO pay it off before, as the interest is acruing, and forgiven ONLY if paid before the promotion is over). Clopay.
    The HD version of this door is 2" thick and has a higher R factor than the pro version, which is 1-3/8" thick. They use different spring systems, the HD version is easier and safer for a DIY'er to install.
  4. Mike50
    Jan 8, 2006
    Southern California
    Thanks. I need to decide if I need/want the insulation up here in the high desert. Soundproofing is a non issue. The 600.00 price was installed with all new hardware. It's a roll down and the cables have seen better days. Anything will be an improvement as mine is an old substandard fiberglass door and it has a crack as well.
    Bottom weather stripping is important as this time of year it's not uncommon for Rattlers to enter the garage seeking shade. I had an encounter with a "Mojave Green" last year. Not good. heh.
    Mike
  5. jadnashua
    A metal door with injected foam (rather than glued on pieces) is much less prone to dents, but if you do get one, it is harder to repair.
Similar Threads: Garage Door
Remodel Forum & Blog Garage Door Wall Button Console - How to Open or Remove? (photos) Jul 30, 2012
Remodel Forum & Blog Garage Door Opener The Saga Continues May 14, 2012
Remodel Forum & Blog Garage Door Opener Spring/Trolley Nut Apr 24, 2012
Remodel Forum & Blog Overhead garage door repair - frustration Jan 10, 2012
Remodel Forum & Blog Garage Door Opening Wall 2x4 or 2x6? Aug 11, 2009
