new ferrule install after pulling old ferrule will sleeve puller
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cjs1996, Jan 8, 2007.
  1. cjs1996
    cjs1996 New Member
    Nov 29, 2006
    Texas
    new ferrule install after removing old ferrule with sleeve puller
    Hi folks, replacing a toilet, and I used this pasco sleeve puller (see attached) that has been mentioned on this forum, to remove the old compression nut and ferrule.
    The old ferrule was quite snug, and when I removed it with this tool, it was tight during the entire pull. This part of the copper tubing is now shiny (from the friction/abrasion of the old ferrule).
    When I put the new nut + ferrule on, I notice that there was a little bit more play in the ferrule than I expected, in other words, it just wasn't snug on the OD of the pipe. In relative terms, when I slid the ferrule further back (behind where the original ferrule was) it was a bit snugger.
    It seems that pulling the previously cinched down ferrule with this tool has reduced the OD of the copper pipe ever so slightly.
    Is this going to be a problem for the new ferrule+nut? Or will the new ferrule conform?
    Terry has mentioned that he uses this puller, I'd be grateful to know if what I've described above is a normal side effect of using this tool. Or is this an indication that the old ferrule was too tight and I'm now looking for trouble?
    If so, what are my options? Can the pipe be resized?
    Thanks
    Chris
  2. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    That's a normal side effect. Tighten down the new nut to the new valve until it feels sufficiently tight...DO NOT overtighten. I like to use two 8" adjustable wrenches so that I don't over torque. You can always tighten up the nut if there is a drip...a 1/4 turn at a time.
    Good luck.
  4. Terry
    Aug 17, 2004
    There is the rare times that the pipe can be too small, indicated by a very visible reduced size from where the ferral was.
    95% of the time though, even though it's a little smaller, it will still work.
    For those times that was squeezed down too tight, it may need to be cut shorter.
    And yes, it is a tight pull, getting off the old stuff.
    [​IMG]
    [​IMG]
  5. cjs1996
    cjs1996 New Member
    Nov 29, 2006
    Texas
    puller
    Thanks for the replies..
    Yes, it worked, but it didn't "feel" very good to me. There was some play between the ferrule and the OD of the pipe. There wasn't enough pipe coming out of the wall to cut and re-seat the ferrule, so I had to make do.
    I went ahead and tightened it down, and it tightened down smoothly. Dripped slowly at first (1 drop in 30 minutes), tightened quarter turn and it's been holding tight for a few weeks now, so I guess it's OK.
    Not sure I want to have to do that again... :)
  6. Terry
    Aug 17, 2004
    After you do a few hundred, you don't even think about it.
    I would much rather replace the old things than to leave them on.
Similar Threads: ferrule install
Plumbing Forum, Professional & DIY Advice Alumipex Ferrule and nut Nov 16, 2015
Plumbing Forum, Professional & DIY Advice Replacing Toilet Water Valve, should I remove old ferrule and compression nut? Aug 9, 2015
Plumbing Forum, Professional & DIY Advice Unusual, to me anyway, ferrule for a compression fitting Oct 12, 2013
Plumbing Forum, Professional & DIY Advice Ferrule for polyethylene compression fitting Nov 30, 2012
Plumbing Forum, Professional & DIY Advice Attaching ferrule to plastic tubing Jan 30, 2012
