New faucet leak, tub tile panel Q
Discussion in 'Remodel Forum & Blog' started by KJones, Dec 18, 2005.
  1. KJones
    KJones New Member
    Dec 18, 2005
    Michigan
    Hi all,
    Am halfway through a bathroom remodel, and just noticed that the new tub faucet is dripping. It's a single-handle Price-Pfister and will be returned, but it brought up some concerns.
    I currently have an access panel in the room behind the bath that allows me to get to a couple of valves that I installed, but there is no way to get to the faucet through it. Luckily for now I can get to the faucet through the front, but that won't be the case once I put in the backerboard and tile!
    Looking around various web threads, I see a lot of posts about maintaining faucets for leaks, getting cartridges, etc. So I am concerned that down the road I will have to choose between living with a drip or tearing out tile to fix/replace a faucet. Can this cartridge be replaced from the front without removing the faucet?
    OR, I could tear out the faucet setup now and redo the mounting boards so that I could get to the faucet from the rear.
    What is normally done for a tub setup, anyway? And what should I do here?
    KJ
  2. Cass
    Cass Plumber
    Nov 12, 2005
    As far as I know all shower valve cartridge replacements are done from the front of the valve and can be done on an installed completed shower by the removal of the handle and cover plate. Valve replacement is more difficult from the back but is better than ruining the shower walls.
    I would pull the current valve apart and see if there isn't a small peice of soder Ect. causing the leak.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    price fister is junk
    check out the valve and see if something is in it...
    odds are that their is not ....
    that brand is just junk and i would not recommend
    it to my worst enemy
    Take it back and get a 1700 DELTA
    while you still got the opportunity
    and you will live
    haiiply ever after.
  5. KJones
    KJones New Member
    Dec 18, 2005
    Michigan
    Cass- Good to know I can replace cartridge from the front! Have figured out that I could cut the mount board from the rear and then put it back with a couple plates, if it comes to that.
    Mark- Almost got a Delta, but I'm a newbie and all it's mounts were different from the old faucet setup (which I ended up largely redoing anyway). Have seen just about all brands dissed on this and other boards, but sadly haven't seen anything close to a consensus. I will take another look around when I take back this one, but don't really want to change the plumbing again (convince me!).
    Thanks for the quick replies!
    KJ
  6. Cass
    Cass Plumber
    Nov 12, 2005
    The 2 most common I would guess would be Moen and Delta.
    Personaly I recomend Moen. It has 1 part to replace. Delta has springs, washers, a ball, rubber seal cap, Ect.
    I like them both because parts are avaliable everywhere.
    Other companys parts can be harder to get.
  7. KJones
    KJones New Member
    Dec 18, 2005
    Michigan
    OK, pulled the valve apart. Didn't find a "cartridge" though, it has a metal ball that seals against various washers and springs (like the Delta, eh?). Didn't find any visible debris, but ran it with the ball out just for luck.
    Still drips, about twice a minute, eventually stopping...
    KJ
  8. Cass
    Cass Plumber
    Nov 12, 2005
    Try replacing the 2 washers. If that doesn't work replace the ball. If that doesn't work install a Delta or Moen. Like Mark said that brand is junk.
  9. jimbo
    jimbo Plumber
    There is an adjustment collar to adjust the pressure against the springs; and often I just stretch the spring a tiny bit.
  10. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    On a Delta, the ball adjustment is with two slots in a plastic ring under the dome cap under the handle. You don't even have to turn off the water, just remove the handle, and you'll see the plastic ring around the top of the dome cap opening.
    In fact, it's best to have the water on so that you only have to adjust it tight enough to stop it from leaking. You don't want to get it too tight anyway because it will cause the rubber seats on the springs to wear faster.
    Delta has a little tool that comes with its repair kits with an Allen wrench on one end to remove the handle, and two metal prongs that fit the adjusting ring on the other.
    If you don't have one of those, simply use the ends of pair of needle-nose pliers in the two slots and turn it clockwise to adjust it tighter.
    Maybe your faucet has an adjustment ring similar to that, and you won't have to replace it yet.
    Good Luck!
    Mike
  11. KJones
    KJones New Member
    Dec 18, 2005
    Michigan
    Price Pfister is sending out a kit. I think it includes the ball, washers, and springs.
    Will live with what I got and finish the tiling, hopefully by Christmas...
    KJ
Similar Threads: faucet leak
Remodel Forum & Blog What to look for in a lav faucet when PSI low Jun 27, 2016
Remodel Forum & Blog Main shutoff and outside faucet pressure fix Jun 21, 2015
Remodel Forum & Blog Help with Delta 200 Wall Faucet Jun 13, 2015
Remodel Forum & Blog Kitchen faucet with pull out opinions? May 29, 2015
Remodel Forum & Blog Grohe faucet help -- British thread 'adapter' Sep 25, 2014
