New electrical work question
Discussion in 'Electrical Forum discussion & Blog' started by ShockHazard, Mar 2, 2013.
  1. ShockHazard
    ShockHazard New Member
    Nov 1, 2012
    Independent Contractor
    North East Pennsylvania
    Im sure there is a device for this.
    Say for example, you wanted to add an oultet in a wall. Is there not a sensor you could drop in the wall, which you would find with a detecting device from the basement so you could drill the hole through the floor?
    If not, what is the old school method for doing this?
    What if you were doing the same on a second floor?
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Old school would be to use a ruler.
    John
  4. hj
    Old school would usually look for for an electrical wire going into that wall from the basement and measure to where you want to be. Or drill a small hole at the base of the wall and stick a wire through it. Or tie a string to a small powerful magnet and then use a compass in the basement to locate it. Greenlee also makes long, flexible drill bits, with extensions, that you push through the opening to drill the hole.
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    When going from 2nd floor down, it's easiest to cut a hole in the wallboard above the baseboard and fix it when you are done. From an unfinished basement or crawlspace, i look at existing penetrations and/or nails coming down from above to determine where the walls are and measure from there. When uncertainty exists, I sometimes will drill an 1/8" hole down from the floor above, angling the bit so it comes through at the center of the bottom of the bottom plate. Once this is done, the hole is used as a reference in drilling up from below.
  6. ShockHazard
    Nov 1, 2012
    I really like the magnet concept.
    Still, I'm surprised there isn't a simple device I could but to do the same thing. Will a compas read between a subfloor and floorplate?
    Measuring has screwed me in the past, because my only reference point is the interior walls, versus the basement walls, which may differ substantially.
    I don't want to cut a hole and fix it because there are too many custom paint colors and people demand invisible instalations. I've had people complain about access holes I've drilled in closets to repair shower controllers.
    Thanks.
  7. hj
    quote; I've had people complain about access holes I've drilled in closets to repair shower controllers.
    There is only ONE shower controller repair that needs an access hole and I am sure you have not run across it. Otherwise the only think that needs a hole is a shower valve replacement. A compass needle is finely balanced so it should have some response, regardless of how little when it is on edge and passes under a magnet. A commercial "dip needle" use a compass needle on the end of a handle to locate buried metal objects. There are devices, sending units and receivers, which while not exactly "simple", are effective and expensive.
  8. CanOfWorms
    CanOfWorms Member
    Feb 17, 2013
    Appraiser, Property manager, Realtor, DAD.
    New Jersey
  9. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That will work.
    You can also use a magnet and detect it with a Cheap Stud finder, or metal detector.
Similar Threads: electrical question
Electrical Forum discussion & Blog Quick electrical question Aug 31, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Pool electrical question Apr 11, 2015
Electrical Forum discussion & Blog Kitchen Remodel Electrical Question: Feb 10, 2015
Electrical Forum discussion & Blog Random electrical wiring questions May 27, 2013
