New drain in a basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Baker5555, Oct 2, 2004.
  1. Baker5555
    Baker5555 New Member
    Oct 2, 2004
    I’m hoping to move my washer and dryer from an upstairs hallway to the basement. The new location has good access to water pipes, but no drain. It is about 10 feet away from the cast iron waste pipe for the rest of the house. It's also about 8 feet from a 3" PVC line that goes from the kitchen into the concrete floor, and presumably on to the waste pipe.
    Is it possible to tap into the cast iron pipe to install a new drain line?
    If I tie into the 3" line from the kitchen, will I overload the line if I use the sink and washer at the same time?
    Is there any advice or warning you can give me about moving the washer?
    I appreciate any info you can give me.
Similar Threads: drain basement
Plumbing Forum, Professional & DIY Advice Proper venting of washing machine and sink drain in basement Mar 13, 2017
Plumbing Forum, Professional & DIY Advice Basement leaking - want advice on Waterguard or similar interior drainage systems Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Need Help with Basement Bathroom Drain/Vent Nov 15, 2016
Plumbing Forum, Professional & DIY Advice 4" Storm Drain into Basement... Oct 9, 2016
Plumbing Forum, Professional & DIY Advice Closing off Basement floor drain Sep 27, 2016
